Question about Recoton Advent Advent Q2035A 20" TV
Color on Advent HT2751A model that stays red, green, and pinks and it wint change
I My Advent HT2751A tv wont change colors. No matter what I do with the the different option in the menu. i have an advent hd tv monitor 1080i or L080i serial number HT2751A. i turn the tv on and the screen is black with red, green, etc. colors or it turns black with white lines running horizontal in a choppy motion. i took the back off and was messing with the black wire going into a rubber black round piece at the top of the tv with two little wires going into the tv, and it looks like one of the wires is broken. when i play with it and touch it back to the tv the picture is better is that the problem? and if so how do i fix it and where do i get a new part? and whats it called? thanks in advance.
SOURCE: 27" Advent Flat Screen TV: Picture Missing but can hear sound
High Voltage. Check fly back Xformer.
Posted on Jan 01, 2008
  • 92 Answers
SOURCE: advent 32" tv flat screen
It's likely one of two things. There are drive transistors on the CRT board which control the output to the guns, the one that controls the red gun may be open, also check this board for burned resistors. It could also be a bad picture tube although this is less likely. If it is the tube, replacements if available are fairly expensive.
Posted on Oct 17, 2008
h_leslie
  • 27 Answers
SOURCE: MEGGAPIXELS OF THE ADVENT 5431 LAP
the answer to your question is 1.3 megapixels....hope i was helpful to you....
Posted on Dec 17, 2008
jhall1793
  • 60 Answers
SOURCE: screen is red
jmeek: unfortunately there's not much you can do about this one. it's either the red gun in the crt has shorted, because of impurity build-up, or the driver for the red gun is shorted. either way it's repair or throw away time. tv repair shops used to carry a picture tube reconditioner that would zap the color guns in the crt to burn-off the shorts. it's doubtful they would have a socket that would fit your crt, but they might. they could possibly find a replacement for the driver if it's defective. but given the low cost of lcd's, that's i would be going. be sure to recycle the monitor correctly. please don't just toss it in a dumpster. there are computer part recycler's thru-out most of the US.
peace-out
Posted on Jan 10, 2009
SOURCE: advent 4211c web cam set up
have you tried the Fn + F6 key combo? you can then use the cyberlink youcam software that is on the programs menu - i think you might have to register the software whne you first set it up.
Posted on Jan 26, 2009
Connecting from laptop to tv wont work now. It was working fine previously
Check the display settings on your laptop to see if the external monitor output is disabled. There is usually a function key on the keyboard with a picture of a monitor on it which can be used to switch between internal & external monitors.
You may also need to try on another monitor/TV or change the HDMI lead.
Sep 27, 2012 | pcb Advent 5711 5431 Laptop M/b U41iix...
Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jul 22, 2009 | Recoton Advent Advent HT3251A TV
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
The picture on my Advent TV HT2751A is curving inwards.
Hi, although I have all sony tvs in my house, every room brand new, when there broke there like a opened bottle of wine ,FLAT, no good!! A 27 is so cheap its worth buying a new one. UNLESS you live where you have friends that fix them on the side. I do and if you ever get to seethe inside of the tv you will wonder what your paying for there is only a few parts in them now and my friend chks them with a machine in 10 minutes if it is worth fixing he has the parts on the shelf and it must be under 100 or its going in the barrel. I have had 1 fixed 10 minutes still good other 1 he threw it out. That's all I can do for you from here, sorry, good luck, Frankie
May 07, 2017 | Televison & Video
Ready for nat'l digital transition?
If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
May 23, 2008 | Recoton Advent Advent HT3251A TV
Looking for schematics for a Advent TV HT2751A HDTV?
try this
http://www.servicemanuals.net/
Jan 04, 2008 | Televison & Video
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Recoton Advent Advent Q2035A 20" TV Logo
73 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
