Question about Sony KP-51WS500 51" Rear Projection Television
Shifting red colors
I have had no issues with my Sony. All of the suddeen we turn it on and the red color has shifted a bit to the right and up. How can I reset the converengence? On old CRT units I would say to do a degausing but I don't think that will work on this set.
    Genius:
  • 2,920 Answers
Your best bet is to call a repairman out and have him fix it so it wont happen again
Posted on Nov 04, 2008
What causes erratic shifting, ford f150, 1999. Fluid is fine, just shifting all over the place
what color is the fluid -bright red or brown ??? if brown change the filter & oil-if it dont work then the clutch packs or servo needs replacing
Oct 04, 2016 | 1999 Ford F150 Regular Cab
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Severe color banding and color shifting for skin / hair tones
Think u got some kind of magnetic field interference.Move ur tv set to the right or left couple inches,just make sure not be to close to ur other electronics devices.Go in ur tv menu.Go to PICTURE.Go down to reset,the setting will go back factory setting,so the colors.See if that help.
May 08, 2010 | Sony KDL-46W5100 TV
Eratic shifting of gears at speeds of 55 to 75
I would check the transmission fluid level and color, should be a nice clear red color. You may need to have the filter replaced. Possibly some internal transmission problem also.
Mar 11, 2010 | 2002 Jeep Grand Cherokee
KP-43170 Sony Projection TV is blurry
Try this site www.my.electronicshelponline.com they have list of free schematic diagrams/service manuals including repair and troubleshooting tips. Good luck. Hope this help.
Jan 26, 2010 | Sony KP-51WS500 51" Rear Projection...
1996 GMC Surburban 1500 2wheel drive. Transmission shifts hard, turn engine off, crank engine and drive off ok. After a while it starts shifting hard again.
what RPM's is it shifting at?If it seems to be shifting a lot more then usual it could be a torque converter problem(locking and unlocking),for now I would try having the tranny serviced and see if the shop can adjust the shift points,also check the tranny fluid for color,amount,and smell.It should be a pinkish to red color and not smell burnt,as far as checking the fliud level run it around until the vehicle is up to running temp and follow the instructions on the dip stick for proper procedure.good luck.
Dec 28, 2009 | 1994 GMC Suburban
Color shift to green on non hd channels
change out your box. thats why they rent them. they anticipate your going to have issues thats why they rent them. i have gone through about 12 boxes over 5 years. change res to 1080i
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
HP Color LaserJet 2600 Printer color shifting
this will solve the problem... check out this link
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Color LaserJet 3500 Printer
Color shifting
this common to dlp projectors! THe DLP wheel has a problem.it has lost its alignement
the best way to solve this is to gt a new dlp wheel replacement
Feb 08, 2009 | Sharp XR-1S Notevision DLP Projector, 800...
Sony KP-51WS500 51" Rear Projection Television Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
