Question about Maytag Atlantis MAV6000 Top Load Washer
Lint on clothes
We cannot find a lint filter on the machine but the washing is covered in lint when it comes out of the machine.
  • eienaj Jun 16, 2008
    I have been having the same problem from the time my machine was new/lint on clothes/no lint filter found. Also my clothes are getting snags on fabric. especially fine silky fabrics.
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Always consult your user's manual first to find answers to common laundry problems. This will give you crucial information based on the specific model number of your machine. Below is a link to a popular website for obtaining manuals.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
From past experience, this complaint is usually resolved with the use of adding more detergent, which softens the water and helps lint "slide" off your clothes As for the lint filter, try looking in the center of the agitator by removing the fabric softener dispenser...No guarantee that's where you will find it!
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
SOURCE: Don't washing machines have lint filters?
Most washing machines I've seen don't have lint filters.
Posted on Apr 28, 2009
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Posted on Mar 14, 2010
  • 1937 Answers
SOURCE: Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
Posted on Apr 13, 2010
Testimonial: "The answer was sent back quickly. The information was very helpful."
  • 15935 Answers
SOURCE: On inglis direct drive washing machine excessive lint on clothes and can see no visible lint filter
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
  • 192 Answers
SOURCE: Cannot get out and clean
Manual is here...
Go to page 26 for instructions.
Posted on Mar 20, 2011
My dark clothes come out of the washer covered in lint. What's up with that?
The lint may be that a particular garment should not be washed in a machine. Don't wash clothes with something like a bath rug.Be sure pockets are empty and that you are getting disolved paper on your clothes. The color of the,lint might give you a clue about it's source. I have often wondered why lint in my belly button never matches my clothes, so lint can be mysterious stuff. good luck.
Jan 24, 2015 | Washing Machines
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Hi I have a Maytag Atlantis MAV975OA top loader. I cannot find a lint filter anywhere and my washing is coming out covered in lint. Can you tell me where the lint filter is so I can clean it? Thankyou
Hi gmallard, it doesn't have a lint collector. This machine is a piece of junk. We're going out today to buy a new one after years of brushing down our clothes with lint brushes. I'll put the Maytag in the shed to wash my dogs pillows etc. (about all it's good for)
Jan 03, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Apr 12, 2010 | Kenmore 24902 Top Load Washer
Washing machine lint trap
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Can't locate lint filter
I'm not sure that there is a lint filter, sounds more like a rinse problem. check cold water supply and any screens in the valve
Jul 17, 2009 | Washing Machines
Lint and dog hair does not come off clothes anymore
mine does that too. I just put a dryer sheet in the dryer with the clothes and it all comes off.
Mar 10, 2009 | Kenmore Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
