Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson not working
Was just using my vacuum and it stopped working. no funny noise to warn me something was wrong, it was like it had just been turned off. Had same problem...but if you go through the entire system, usually some small piece is blocking the airflow. Can be very small and typically in the elbow pipe on the underside. Just make sure everything is free. Mine started working once I cleared this small little plastic piece.
  • 1 more comment
  • Anonymous Jun 30, 2008
    Mine had the exact same problem. Just shut down mid-push. I read your answer, took it apart (very easy, no tool required) and took out some clog. Now it is perfect!! Thanks!
  • VHa4 Jul 26, 2008
    My Dyson just shut off in mid push and I've cleaned out the elbow and washed the filter but still no luck.
  • toniamichell Sep 29, 2008
    I have the same problem but i cant get the parts back together after unclogging the vacuum. I have a piece of **** that is worth over 500 dollars.
  • 3 Answers
SOURCE: dyson not working
I suggest you check the hepa filter for black soot. If it is black and yucky then the motor is probably burnt out. Check out the guide at for instructions on how to fix it.
Posted on Jan 14, 2008
SOURCE: Cannot reinstall valve pipe assembly on Dyson dc17 vacuum
Take off the cyclone canister and flip open the filter cover. (The U-shaped tube at the bottom of the vacuum is probably already off-if not, release the lock with a screwdriver and remove it.) Release the vacuum from the upright positon, so that the head is extended. Align the value pipe assembly so that the clear tabs line up while the small extension off the value pipe faces the front of the vacuum (ie, is near the filter area). Now you have to carefully twist the value pipe clockwise while lining us the small extension with the black groove inside the head piece by moving the head back into the upright positon at the same time. Replace the U-shaped tube.
Posted on Apr 30, 2009
  • 27 Answers
SOURCE: dyson elbow tube clogged
turn the vac upside down then stretch out the hose the stick will eventually fall out
Posted on Oct 03, 2009
  • 1486 Answers
SOURCE: Blockage in pipe of my dyson slim dc18
There sould be a rubber flap under the pipe.Pull it down to remove dust and **** that gets stuck.
Posted on Dec 27, 2009
Testimonial: "He was very helpful in his suggestions and after the first suggestion didn't work out he provided another. Thanks for the help."
  • 3301 Answers
SOURCE: Hi, my puppy ate the
any vacuum place will have replacement cords and they are easy to replace,, Just take the make and model number with you, they may even replace it for you at no or minimal charge
Posted on May 31, 2011
Testimonial: "Thankyou - I'll give some local vacuum shops a try."
Does Dyson dc17 have a reset button to restart brushes
Please review the material here:
Feb 22, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why is my DC24 not working
You may have an object caught between the belt and brush roll.
Remove brush roll cover and see if that is the case.
Aug 23, 2014 | Dyson DC24 All Floors Upright Cleaner...
Grinding noise intermitent when brush engages
Hi Ronald,
Your Dyson's brush control system is designed to make a ratcheting sound to warn you if something is jamming the brushbar. To resolve this, please follow the steps shown on our Support page:
If you'd like any further assistance or advice, please get in touch with us directly by calling free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Dyson Online Customer Support
Feb 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson will not switch on
Usual problem is the fuse in the plug. Check the fuse first. If this fails then your problem is either the Switch (Unlikley) or the Motor. Its unlikely the motor would break without warning though. If you have had any burning smells or funny noises recently then its the Motor.
If there are no Smells then im confident its only a case of changing the fuse. Quite common for the fuse to go.
Oct 23, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
When in carpet mode, brushes seem to be hitting something. Brushes cleaned - how to stop making the awful noise
LOL do you mean when you move the vacuum forward (say into a baseboard)? it makes the loud shocking noise.. i hate that too.. but that's the crazy Warning sound indicating something is stuck (like you sucked up an area rug) or you have run into something and it set off a sensor.
Mar 26, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson vacuum cleaner doesn't start
check if something is stuck to keep the motor from turning
Mar 18, 2009 | Dyson DC05 Bagless Canister Cyclonic...
Dyson not working
Dec 02, 2007 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
71 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
