Question about Apple iPod MA446LL/A MP3 Player
30 gb apple ipod...
I own a 30 gb ipod and it doesn't charge via USB cable to the computer it will only display very low battery and every few minutes show the apple backlight. While on the USB cable it also doesn't let me transmit or receive music. The only way its able to charge is with the wall charger.
  • 137 Answers
Try to access the Settings on the iPod menu and locate the section where you tell it to charge.
Posted on Jun 26, 2008
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
30GB iPod video has been charging for 13 hrs, still won't turn on
Have you tried the usb cable in a different port or if that does not work try a different usb cable. Or try your ipod on another computer. Hope this helps.
Apr 01, 2010 | Apple iPod MA446LL/A MP3 Player
My ipod wont turn on
If your ipod won't turn on then try these.make sure you click on the blue links for more info.
ts1383_2.jpg To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Update iPod's software If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
May 16, 2009 | Apple iPod nano
NOw what?!
Hello again Cholo, Well, we?re going into uncharted territory for me since I haven?t had this happen, however, I have found some additional things to try. -Check and make sure the hold switch is off (orange is hidden). -If the battery is completely dead it may take as long as 30 minutes of charging for it to respond. -Let the power drain completely: Disconnect the iPod from all power sources (apple charger, firewire and USB) and let it sit for 24 hours. Please note that you will probably loose all music and anything else stored on the iPod. After 24 hours reconnect it to the power adaptor or your computer and try resetting again. If it still doesn?t work try letting it charge for 30 minutes. If you get it running again Apple recommends you download the latest version of the iPod software updater and update the iPod. If none of this works try the following: -Connect you iPod to another computers working USB port making sure it?s the only USB device plugged into the computer except you mouse and keyboard. Try letting it charge again. -If you?ve been using one source (USB or apple charger) to charge exclusively try the other. -If using a USB cable make sure its the cable that came with your iPod and that it is in good shape. -If you get this far you probably have no choice except to send it Apple for repairs. Let us know how it goes and please don?t forget to rate the posting.
Jan 17, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
140 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
