Question about Kenwood KRF-V5060D Receiver
Kenwood kr-v9020 This is an old receiver and can't find anywhere else to post my problem. It's with the remote control for the volume. Everything else works with the remote except my volume up and down buttons. But it's not the remote, cause when I push the up or down button the blinking light on the volume knob of the receiver blinks, so it is getting the signal. Could this be the motor of the volume knob, if so, is this an easy fix, or does it have to be done by a repair shop? Thanks I hope someone can help
    Genius:
  • Kenwood Master
  • 1,673 Answers
You should find out who does the service for your reciever in your area. This type of fault can get fairly involved. It will require trouble shooting and then ordering the necessary parts.
The fault can be the motor, or the electroncs in the servo drive amplifier for the motor.
Jerry G.
Posted on Jun 10, 2008
My kenwood kr-v7030 won't turn off anymore with remote or manually.
Either the remote battery are flat or the frequency settings have changed. You can check with the manual the type of frequency it uses to match the that of the Kenwood. Sometimes there are switches you can change to adjust the correct frequency. Others have a learning code set by the manufacturer and are usually in the operation manual. If you want to test whether the remote is transmitting the signal to the Kenwood or not, Please do this...
If you have a digital camera or smartphone camera, switch the camera on and look at the viewfinder or camera screen; for smartphone, in a moment, then point the remote to the camera lens and press the volume button, which keeps sending the signal to the to control the volume of Kenwood system. If you see the infrared light on the remote flashing, then the remote is fine.
Now, about the smartphone camera. Start the camera and switch it for video capture (filming) and then point the remote towards the camera lens, and likewise you should see the remote light when doing the same tests as you with the video camera. If the infrared light lights up when pressing on the volume, the remote is fine.
It could be Kenwood, which requires factory repairs, not by you.
Dec 22, 2014 | Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
Yesterday, I connected two speakers to my Kenwood KR-V7070 Receiver and it worked fine but today I can't hear anything coming out of the speakers. I may have pressed a wrong button on the remote. Also,...
Tell us some details about the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V7070-Receivers-manual/id/479bh947/t/2/
Familiarize yourself with the controls. Understand every indicator on the front. There may be a clue there. Turn the volume to a medium or low level before changing any settings or you may be in for a BIG (and costly) surprise when you find the one that was in the wrong position.
Let
Mar 02, 2011 | Kenwood Audio Players & Recorders
Kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Jun 07, 2010 | Audio Players & Recorders
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
I'm just trying to find out if the Kenwood KR-V7050 has an optical input for an adio connection for a Blu-ray player.
Sorry, no digital inputs at all. It's a stereo receiver from the 80's.
I have the KR-V9020 and it is probably among the most feature-laden pre-digital surround receivers built. I still use it in a bedroom even though I have a full-blown 7.1 rig in the living room.
Dec 26, 2009 | Audio Players & Recorders
Sound problem
Try cleaning the volume control with an electronics switch cleaner spray. If that does not resolve the problem and it seems to happen at low volumes more than load volumes, then the output relay needs to be replaced. Keep us posted. Dan
Jun 12, 2009 | Kenwood Audio Players & Recorders
Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Jan 08, 2009 | Kenwood KR-V5580
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Kenwood KRF-V5060D Receiver Logo
712 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
