To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website:
http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
