My midterm is tomorrow and I had a panic attack not knowing what to do w/this calculator (just got it yesterday). I am so relieved, thanks for this!!! Appreciate the help :)My midterm is tomorrow and I had a panic attack not knowing what to do w/this calculator (just got it yesterday). I am so relieved, thanks for this!!! Appreciate the help :)
You can't post conmments that contain an email address.
Yes. Simply enter the fraction and press =. If the calculator is in the MathIO mode it will display the fraction in its simplest form. If you're in the LineIO mode, press the S--D button to convert the decimal to fraction.
To convert a single value from symbolic to decimal form, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
On the fx-115ES, to convert a single result to decimal press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
Yeah? What do you want with it?Do we have to play good cop, bad cop to make you reveal what you want? Could be just a fraction 1/5 or a decimal number 0.2 If you calculator gives you a fraction use the [S<->D] to convert it to a decimal number. If it gives you a decimal number, you can convert it to a fraction by pressing the [S<->D key.
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
