Question about Frigidaire GLTF2940ES Front Load Washer
Cycle won't start, error "ddo" displays after about 30 seconds and also code E14
Any clues as to what is wrong?
    President:
  • 1,294 Answers
Your dispenser drawer has a magnet in it that has to line up with a sensor. If you can put the drawer back in that will solve the problem, if the magnet isn't lost.
Posted on Jun 14, 2008
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire Front Load Washer during its cycle usually 24 and 16 min into the wash cycle it will stop and beep giving a E10 error message. What does this mean?
The cause of the error is that no cold water is getting through the cold water valve (inside the machine).
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
  • E11 - Fill time too long. (See test 1 below)
  • E13 - Water leak in the tub or air leak in the air bell. (See test 2 below)
  • E14 - Dispenser drawer reed switch is open. (See test 3 below)
To recall the specific fault code from this group, follow these steps:
  1. Wake the machine by pressing any button
  2. Wait 5 seconds
  3. Press and hold the Start and Pause/Cancel buttons simultaneously
  4. All LEDs will go blank and after a few seconds the control will signal the stored code
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
http://appliancejunk.com/forums/index.php?topic=1364.0
That website above directly addresses your issue.
Jun 01, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code: E14 Reed Switch
reeed swith id a small magneteic door switch, i believe frigidaie has taken the m out of newer machine( caused more problem then worth. i would check to see that all doors are closed all the way, especially the dispensor door. theres a slot on the inside of the dispensor assy that holds a small magnet( again theyvce removed from most newer production ) perhaps yours (if indeed oyu had one fell out or became dislodged in moving the unit
Oct 23, 2008 | Frigidaire FWT449
Frigidaire Front Loading Washing Machine
possible rear drum support problem the support has started deterioating and is coming into basket ..have you noticed a loud roaring during spin if so rear bearing may be gone as well..ask for estimate before repair.
Aug 27, 2008 | Frigidaire FWT449
Frigidaire GLTF2940ES Front Load Washer Logo
424 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
