Coleman ac unit
The compressor was never bolted down and now the copper pipe has broken. Is this worth fixing or not ? If it is worth fixing, how much does something like this cost?
    Champion:
  • 254 Answers
If this would be worth fixing would depend on how long the unit ran after the tubeing was broken and how long it has been open for to determine if any contaminants were introduced into the system. A good technician would come out and braze the lines back togather, bolt down the condenser, purge the unit with nitrogen, and pull a deep vaccum before recharging the system. If this were done and your system worked fine which should be the case. It would save you the cost of a new condenser.
Posted on Jun 10, 2008
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
Upka 035jaz
First turn off the breaker to the unit. Then disconnect the wires from the compressor making sure you right down which wire goes to which terminal. Using an ohmmeter place one lead on any copper pipe inside the unit. put the other lead on the terminals in the compressor one at a time. If you have continuity from any terminal then the compressor is shorted to ground. the other method is to record the readings across each terminals (run, start and common) the two lower readings should equal the higher reading. If not then the compressor is either internally shorted or open.
Sep 01, 2014 | Heating & Cooling
Ac not cold
The AC unit has 2 copper pipes, 1 is larger, this one should be "beer can cold" in AC mode, if not its low on refrigerant or not running.
Aug 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My central air AC unit (Double wide home) always works for generally up to two hours, then it freezes up, by the copper pipes ice over, shutting them off and letting them thaw out, works to get it going...
You are absolutely right! The copper pipes should have insulation them. When they don't and they get cold in hot weather, they sweat and then freeze. Tubular Foam Insulation is what you need. Most home centers carry it. Once you cut and install it, be sure to wrap it in a good quality Duct Tape.
Hope this helped you. Good luck.
Jul 15, 2011 | Coleman Heating & Cooling
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
Air runs but wont get cool
Hello! This could be that the compressor has went bad or that you need to recharge it. Visit your local home improvement store and they should be able to assist you with fixing this issue. If not, you should visit a local AC repair shop, or even call them to ask what else could be the issue and how to self repair. This in most cases is not a hard task to "recharge" the unit. Hope this helps!
Apr 27, 2009 | Coleman Heating & Cooling
Coleman ac problem
could be bad start capacitor for compressor, cheap fix, anything else could be internal in system or compressor
Apr 10, 2009 | Heating & Cooling
2000 coleman mach
It is possible that the compressor has completley failed and is shorted to ground. The way you check is to access the compressor terminals where the wires hook up. After noting the location of each wire, remove the wires from the compressor terminals. Get a piece of sandpaper and shine up a small area on on of the copper pipes coming out of the compressor. Use an ohmmeter and check for continuity between each one of the compressor terminals and the copper pipe. If you have ANY continuity from any terminal(s) to the pipe, the compressor is dead and will require replacement. If not then check all of the wiring to and from the compressor looking for any possible shorts to ground (wire chafing, cuts, etc.) After that, check the run capacitor for the compressor. If the capacitor is failed, it will cause the compressor to draw locked rotor amps. Generally speaking, the quick way to tell if it is a capacitor or a short is to listen to the unit. If it trys to start for a couple of seconds and the pops the fuse, either it is the capacitor or the compressor is seized up. If it trips the very instant that it trys to come on, it is a short.
Jul 01, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
