Question about Car Audio & Video
Speaker input cable
When i try to hook my door panel speakers up into the speaker input cable it doesnt make a sound like my subs hit still but my door panel speakers dont put out any sound
  • 70 Answers
This happened to me before, try checking the ends on both sides and see if they are hooked up correctly, or look qat the whole wire and see if its chewed through or something.
Posted on Jun 12, 2008
Speakercraft v10 subwoofer not taking input signals
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable?
Jan 04, 2014 | Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
Can you please tell me how to connect my kef psw
If your amp has a "sub out" jack, that's the best way to hook up this sub. You'll just need a single RCA (also called "phono") cable. Connect it to the Left input on the sub, which should also be marked as "mono"
If your amp just has speaker-level outputs, then connect the left and right main speakers from your amp to the sub's high-level inputs, and then run wires from the sub's high-level outputs to your speakers.
If you're running a surround-sound setup, use the front-left and front-right speakers for this hookup.
If this helps, be sure to hit the "thumbs-up" button for me!
If not, post back with the "Add comment" and I'll do my best to answer any questions you've got.
Jan 23, 2010 | Panasonic Audio Players & Recorders
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
