Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi Electric string trimmer
I have a Ryobi (RY41002) electric string trimmer. The switch has gone bad. Does anyone know were I can buy a replacement.
The switch is a 10.5 amp 125 volt with the letters cRUus FA3-4 on it. Any help is greatly appreciated.
TJ
  • 3 more comments
  • Anonymous Dec 21, 2008
    Thanks so much! You guys just saved me 1/2 day of driving around looking for this part!
  • Anonymous Apr 22, 2009
    Need replacement switch made by Homelite(part UT41002A-36) used on Ryobi RY41002 15" string trimmer.
  • a2126r Apr 27, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I also have a Ryobi electric string trimmer, it does not last more
    then 1.5 year; the entire time to failure is less than 20 hours. As an engineer
    I would be ashamed for such product. I wonder if there is a recall for this product.
    I will never buy anything from them.
  • Anonymous May 17, 2009
    Same thing. Less than three summers of use (I'd estimate less than five total hours on the motor), and the switch is dead.
    Now deciding whether to replace the switch or just junk the whole thing and swear off Ryobi forever.
  • Anonymous Mar 17, 2014
    how to string an electric trimmer model gh3000
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
I decided to take the switch apart to see why it failed. In my switch the contact arm on one lead had gotten angled off a little so that when the switch engaged it was probably sparking and creating a little heat. The arm melted into the housing at an angle so that the housing then bound up and would not rotate to engage the contacts when the trigger was depressed. I think that the design is just a little too clever to be reliable over time. I expect this is probably the same problem in most other switch failures. Just wedge out the sides of the switch cover to clear the little tabs on the side and the whole top comes off. Then you will see the little teeter-tooter type arrangement inside. The parts are small so be careful to note how it all works before taking it apart so you can get it back together again. Hold the contacts down at the same level as if the top is on. You will see that the lever should push the contacts down when the trigger is depressed. My wouldn't go down because everything was cockeyed inside. Once I got the housing holding the contact arms lined up straight in the switch box, it started to rotate freely and the contacts would then move up and down.- John
Posted on May 16, 2010
I have the same problem. There was a time when Ryobi actually had decent engineering and construction. Sadly, Ryobi is now just more Chinese junk. I will do the switch fix due to many ends, but will no longer buy new ryobi equipment.
Posted on Apr 12, 2010
    New Friend:
After digging thoroughly, I've found out that my local Bunnings (Australia!) is able to order it for me through their special order desk! $11.03! Now waiting for delivery...
Ryobi PN is: 099081003034
Cheers!
Posted on Dec 24, 2016
The switch on my reconditioned Ryobi went bad soon after I bought it. I replaced it with a simple on/off rocker switch and it has worked fine ever since.
Posted on Sep 19, 2010
Is there a substitute switch for the discontinued ut41002a-36 switch for my string trimmer?
For those looking for a source for the UT41002A-36 as a replacement for FA3-4 in the Ryobi RY41002 string trimmer I want to confirm that as of Summer 2015 - I couldn't find any seller still carrying this switch. I likewise could not find a substitute with anything approaching the same form factor. For those questioning whether it is the switch and not the motor and haven't taken time to check, I can confirm that the switch is more likely to be the problem.
Without any options other than wiring in a new external switch or some other hack, I opened the malfunctioning switch. It requires patience to handle the switch internals without having it all "fall apart" but you may notice oxidation (as I did) that can be easily addressed with a little scraping. I am certainly disappointed that I had to fool around with switch internals to keep this lawn tool working but wanted to offer this suggestion to any others who may be frustrated. The trigger switch Ryobi chose is just too fragile for a lawn tool.
I would welcome a reply from anyone who can offer me a "DYI obsession intervention" as I keep wasting too much time that would be better spent on other activities.
Jul 03, 2014 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
The pull cord on my ZR29550 string trimmer is stuck in the fully retracted position. I can't pull it to start the machine. Also the electric starter can't turn it over.
well its not going to start with electric because the cord is out of it...
just take it apart becareful do not pull the recoil out or your in a mess....
but this should help you out if you need to know more just ask...
Aug 18, 2010 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas string trimmer won't run
I obviously posted this under the wrong category. I would post it properly, but I can't get back to where I was (or should be)
Sep 07, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
4,784 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
