2006 Yamaha DT 125 X Logo
1981 Yamaha DT125 no spark
I have a 1981 yamaha dt125 no spark , Can I bypass all the lights and just hook it up like a yz ? i so i need to know what to do to make this happen , My son's birthday is this friday and would like to get running for him so we can go rip up some dirt ...PLEASE HELP THANKS MIKE
5 Related Answers
Anonymous
  • 948 Answers
  • Posted on Feb 14, 2009
SOURCE: fuel for yamaha dt 125
This bike uses unleaded gasoline. At only 6.7 to 1 compression you can use the lowest octane fuel you can find. 87 in the US is what that would be around here, but across the pond the octane numbers are different. But don't forget the two stroke oil. That may be more expensive than your fuel cost.
Anonymous
  • 5158 Answers
  • Posted on Apr 06, 2009
SOURCE: a lot of gas coming out of the carb. overflow tube, eng on or off
the float pin is stuck or has some dirt in it. try tapping the side of the float bowl(s) with the handle of a screwdriver... not hard enough to break it. if that doesn't work you will likely have to take the carb apart and clean it.
Anonymous
  • 44 Answers
  • Posted on Apr 24, 2009
SOURCE: what spark plug for yz 125?
I have a dennis kirk book, the correct spark plug is a --BR9ES--(NGK)
i always used SAE 10w-30 oil on all my dirtbikes,
no transmission fluid
for the chain you should move the back tire back until the chain is at a snug tension
tombones
  • 3567 Answers
  • Posted on Apr 30, 2009
SOURCE: I have a 95 yz 125 head and 98 yz 125 bottom end.
You have a 50/50 chance that they will work okay. All the mounting holes need to line up and the cooling holes as well. Get a head gasket for the '98 and see if all lines up. Will the exhaust pipe fit the '95?
tombones
  • 3567 Answers
  • Posted on May 05, 2009
SOURCE: headlight 1972 yamaha 250 yz
You can add a headlight if the type of ignition system on your particular model is the type that will let you. Several different systems were used back then. The proper system will need a lighting coil installed onto the plate underneath the flywheel. The flywheel must be pulled off. You will see a coil there already for the spark. An unused set of threaded screw holes is present, (the same plate was used on the bikes that had a headlight). Just add the coil and now you have power for a headlight.
2answers
My dt125 has no spark the coil and plug re new and
i have this problem too and its not that
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
