Toshiba TV remote
Saw your name attached to someone with a problem with their remoteon a Toshiba 32af43. TV vol, input are in and out making me think its a loose connection.
I thought it was batteries, changed them... reprogrammed Directv, it now sometimes will control the TV and input, but most of the time not. The Toshiba remote does not work either. It must be the IR LED, but why would it work sometimes and not others?
I took of the back of the TV and it looks tight to get in and solder. I have no clue what I'm looking for or at. Service manulas are available but only for $... I'd rather save the money if it ends up I can't fix it anyway.
If you have any leads... let me know at zenmodo@msn.com
or even 919 599-8198.
I appreciate it.
    Genius:
  • 1,554 Answers
The Ir led is usually behind a dark window, you can locate it by doing a command while real close to the tv,
once you find it then see if it takes commands all the time.
if it takes a command and waits a while to take another then the power to the ir led is likely the issue, as you said it may have a loose connector at it or the connection to the main board.
one way to give it power is to solder a 10 mfd cap across it and it will store some power for you, thats only a temp fix and you will likely get the polarity wrong.
there are tons of Ir leds on the market and even radio shack still carries them. though they are a transistor and need biased , sometimes just replacing them randomly an they work fine as they are all low power.
this is the basic circuit for a detector
http://www.tkk.fi/Misc/Electronics/circuits/irdetect.gif
notice the change in the ir causes a change in voltage and is transmitted down the line.
this is likely what you have in your tv now
http://www.solarbotics.com/products/pna4602/
it has the same circuit inside it
you can monitor the output as it fluctuates but it will be fast.
the next best to save is to just use an external tuner and speakers they will sound better anyway.
Posted on Jun 10, 2008
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
My comcast remote does not work on my tv
Setup codes to check with Toshiba TVs are: 10154, 10156, 11265, 10060, 10036, 10149, 10736, 10832, 11343, 11369, 11704, 11935.
These are codes with Comcast DTA remote control. If you want to know more codes and setup proceedings, check these sites.
Jan 16, 2013 | Toshiba 32AF43 32" TV
How do i inputting to channel 0?
I am not familiar with your particular tv,however on most TV's channel 0 is equivalent to putting your tv on video as apposed to rf (or regular tv channels).Most will have a remote setting for tv/video or it may say source which would give you the option of rf(tv) or video.
Aug 02, 2012 | Toshiba 32AF43 32" TV
Reset v-chip with universal remote
Check this link, and select the site named 'Electro-help' for details. It is very difficult to describe all details here.
Need to program the 32af43 to my dish remote need code
Here you can download entire pdf for the model number mentioned and in page number 15 and 16 you can find codes http://www.tacp.toshiba.com/tacpassets-images/models/36af43/docs/36af43_om_e.pdf
Feb 05, 2011 | Toshiba 32AF43 32" TV
I have a 32AF43 remote has stopped working
resolder the ir sender it sound like it the solder has broken free
Jun 23, 2009 | Toshiba 36AF42 36" TV
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Remote sensor not working
either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
Dec 10, 2008 | Toshiba 32AF43 32" TV
2002 Toshiba 32" TV
I have the same problem with a 2005 Toshiba. Got a new remote...nothing. Seems like a lot of people are having this issue, must be a defect in the TV. Has anyone contacted Toshiba?
Nov 22, 2007 | Toshiba 32AF43 32" TV
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
