My sound on my ASUS OKIA-420ATX is not working
    Problem Solver:
  • 6 Answers
Go to device manager and see if it's got any yellow question marks in there. If it does, your drivers are missing. Also check to make sure the sound isn't muted in either volume control, or the appropriate control such was WAV isn't muted or turned all the way down.
Posted on Jun 10, 2008
  • 100 Answers
Put mb cd and install sound driver.
go to control panel and click add\remove programs and there right click properties device manager and there if u get yellow questions marks in sound device select that and right click and install driver
I have a Power Supply OKIA 550W black, and i whant to know what kind of sensor thermisor I have to use for reparation. Because it burned and I cant read it.
If burned out, it is most likely a MOV surge supressor. Since most PC power supplies are 120/240 vac rated, a MOV of 275 volts or greater would work. The exact values are not critical, as it is for line surge supression.
Jun 13, 2010 | Okia (OKIA550WP4PS) Power Supply
I have a Okia 420ATX power supply. I had it
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Feb 03, 2010 | Okia 420w UL Approved ATX Computer Power...
I have an OKIA power supply that was installed last September. The fan has stopped working allowing the tower to overheat. Is this model OKIA 350-ATX still in warranty?
Yes, the factory provides a 1 year warranty. Since you installed it some 11 months ago I suggest you contact them asap. You'll probably need to provide the serialnumber to them as part of the procedure.
Okia is not actually the full name, the company that makes them is called Broadway Com Corp and their (powersuplly) website is: http://www.bccpc.com/bccpc/power_all.htm
The contact information can be found at: http://www.bccpc.com/bccpc/contact.htm
Aug 12, 2009 | Okia (OKIA550WP4PS) Power Supply
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
Friends custom-build PC has no power
Seems reasonable. Take the motherboard out of the case,  first to see if it will work outside of the case. Sometimes boards short to the ground due to a screw or other metal getting between them and the case. Try to run it with as little hardware hooked up as possible. You don't even need a hard drive to post the BIOS.
Mar 12, 2009 | Okia 420w UL Approved ATX Computer Power...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
My computer turns on but wont turn hdd all the way on it starts then clicks and stops goes to a black screen. and there is a smell coming from the computer. i put the hdd in another tower and it worked.....
If you have a standard atx case then any standard atx power supply should work. Yes you can upgrade to one with more wattage as long as it has all the connectors you need. Hope this helps.
Dec 24, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Fan
Hi replace the fan by opening the power supply with a new fan if your power supply is under warranty period still get it exchanged.
May 19, 2008 | Okia 250w UL Approved ATX Computer Power...
Humming noise
IT sounds like the fan bearings are going out already, or have flat spots on them that cause vibration at speed. Try calling the manufacturer and tell them the fan either quit working or is about to quit.
May 08, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Power Supply Warrenty
I couldn?t find a web site for Okia either; however, I did note that the venders that sold them usually guaranteed them for one year themselves. I would at least try that route, that and not buy Okia power supplies. There are lots of stories and physical examinations of how poorly they are designed and manufactured.
Sep 19, 2006 | Okia / 450-Watt / ATX / 80mm Fan /...
Computers & Internet Logo
David Payne
David Payne
