Question about Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835)
Wireless router it is a wireless router
Only the power light turns on, on my linksys wireless router and i cant get the internet on my laptop.
Posted on Jul 11, 2008
  • 2,794 Answers
Is it a linsys router?
Posted on Jun 10, 2008
  • Tim Babcock
    Tim Babcock Jun 10, 2008
    I can walk you through the process if its a Linksys router.
Which are the best Wireless Routers under $200?
Some of the best wireless routers available under $200 are:-
? Linksys WRT1900ACS Dual-Band Wi-Fi Gigabit Router
? ASUS RT-AC68U Wireless AC1900 Dual-Band Gigabit Router
? TP-Link AC1900 Wireless Dual-Band Gigabit Router
? NETGEAR AC1750 Wi-Fi Cable Modem Router
? TP-Link Archer C7 AC1750 Wireless Router
You can check and compare these wireless routers at:
Best Wireless Routers 2017 Reviews and Comparison
Jan 07, 2017 | Best Computers & Internet
Wireless router woks if wired won't work wireless
Wireless router works if wired won't work wireless
Sep 21, 2012 | Linksys Wireless-G Broadband Router
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
I get limeted access to internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
CAN I SET UP A ROUTER USING A PS3
No, the wireless card in the PS3 is just ike a wireless card in a computer. You cannot turn a wireless card into a wireless router, a wireless router is a special piece of equipment.
You need to purchase a wireless router.
Feb 01, 2010 | NetGear WGR614 Wireless Router
Hi, I have a netgear DG834G version 3 wireless router. I want to buy a wireless printer, will this router support one? If so, have you any opinions on the best buy? Thanks
any wireless printer should and will work with this modem-router as long as it's wireless settings are configured right, if you already have a computer connecting to this router wirelessly then that means the wireless functionality of your router is working. you just have to know the wireless settings of your router such as the SSID or the wireless network name, the type of wireless security and the wireless security key or encryption key.. once you have a wireless computer and it wireless feature is enabled it will automatically detect all networks name or SSIDs around the area, that includes your modem-router's and neighbors'.. when you try to connect to the SSID of your modem-router you will be asked for an encryption key or a password to be able to connect.. that will only happen if you have enabled a wireless security on your modem-router.
Jan 30, 2010 | NetGear DG834G 802.11G Wireless ADSL...
AFRAID OF SOMEONE IS LOOKING MY COMPUTER
Very, very highly unlikely. It doesn't work like that.
Netgear is probably the manufacturer of your wireless card, and the rubbish software they give you is freaking you out.
Nov 18, 2009 | Actiontec (GT704WG) Router
Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835) Logo
141 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
