Question about HP OfficeJet 6210 All-In-One InkJet Printer
Fax does not work, and I don't have the booklet for troubleshooting
I have had the all in one 6210 for about six months. I must preface this with: I am not very "electronic savvy".
The black box that the fax/copier is plugged into connects to the phone line when it tries to fax or receive, but NOTHING will come or go through. When it is trying to receive a fax, you can hear the black box clicking like it is trying to pick up the fax, but it stops after a bit, and begins again shortly when it tries to receive another fax. I am at a loss.
Cannot receive a fax unless someone is there to push the button to reveive. How can I set up to receive automatically?
Posted on Jun 18, 2008
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a rather generic question- should I expect a home/office all in one machine to last more than a couple of years. I do a moderate amount of printing. And should I expect to be able to print...
in simple - NO - No machine is built to last anymore. My experience is genrally between 18 and 24 months is about the life of this tyoe of machine and even if it is still going at that point the inks will become so expensive it is wioth changing anyway
Jul 12, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hi Wondered if you could troubleshoot my Officejet 6210 xi All in one printer to see if the fax portion of the printer is working properly. Intermettingly I can send a fax and it works other times it does...
HP's check for a dial-tone every time you turn them on and will nag you if it doesn't find one.
Do you have DSL or any other type of DIGITAL phone service?
Fax machines are ANALOG devices.
Jan 31, 2009 | Office Equipment & Supplies
Cannot send or receive faxes
Unplug the power cord for 10 seconds.
Jan 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
Aug 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All in one scanning problem
just remove old driver from ADD REMOVE PROGRAMME AND THEN RE INSTALL YOUR PRINTER DRIVER AGAIN.
Jun 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
My hp 6210 will not sent or receive a fax. it us to but now it's not
Verify that you are using the little cord that came with the printer. It is a special two conductor cord. You cannot use a normal phone line to the fax. This cord must be inplace for the fax to work. Go to:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00014834&lc=en&cc=us&product=421991&dlc=en
Mar 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I can't fax... Hp 6210
Have you tried to contact your phone line provider? Maybe the is on thier side. If there is nothing wrong with their conncetion then pls click on the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
If this doesn't help your issue, pls post here and I'll get another solution for you.
Oct 18, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
