Cars & Trucks Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a menualinstruction for the renault twingo?
  • Anonymous Mar 12, 2014
    How to reset clock on Renault Twingo
Gustavo Ortiz
Level 3:
  • Master 637 Answers
  • Posted on Oct 28, 2010
Gustavo Ortiz
Master
Level 3:
Answers
637
Questions
8
Helped
314183
Points
1811
1helpful
2answers
What is the power of engine renault twingo 1998
Depends on the number of valves on the engine. If it has 8 valves (2 per cylinder) it is 60hp. If it has 16 valves (4 per cylinder) it has 75 hp.
How do I know the Alternator is dead or if I need
jump start the car again and then take a the battery lead off any one and if if engine stops then alternator is dead ,this works on 99% of vehicles the exception being the renault twingo /clio models
Removing bumper
go to this link: 2004 Renault Twingo Owner Handbook CZ Download and scroll to the bottom. click read/download and it should automaticly download for you
Hi, so my renault twingo looses power and the square warning light with the wavey like through it comes on. I can then turn the ignition from on to off and everything resets and of we go again until the...
There is a Twingo forum that should be able to help. I don't know that type of car but It does not seem logical to have a sensor under the gas pedal unless it sends a signal to the computer on how much gas to put into the injectors. In that case it would probably be behind the top of the gas pedal. Turning the ignition key on and off would not reset the computer but disconnecting the battery (+) wire for 10 minutes would. I would try that first. Check out the forum if that still does not work.
http://www.renaultforums.co.uk/tags.php?tag=twingo
1helpful
Where is the window washer motor on renault twingo sport
I'm not sure about this car but on most cars the washer motor is at the very bottom of the washer fluid bottle.
Need code for Renault's Twingo radio
Sorry we do not have access to this info. Please contact your local dealer.
2answers
My boot will not open on my renault twingo
Is the cable still connected or did it break if it is intact you can try spraying penetrating oil on the latch that holds the boot closed
What colour fuse is the cigarette lighter in a renault twingo
The best solution is to take it to the garage as no one seems to know the colour or value of the cigar lighter fuse in my 2011 Renault twingo pizaz so replacement will be a case of pulling each one in turn until the right one comes to light
Peugeot 206 removal
Not a difficult job on this car try doing a renault twingo or modus ,what about the mercedes A class thing now thats a job and half ,Disconnect the battery and take your time its not a difficult job .
1helpful
Your help much appreciated. I have a Renault Twingo 1999 model Serial number VF1CO66MG20566300. The steering is extreemly heavy and the power steering warning light is on. My garage said that the...
Hi!
The ( EPS) is the Electronic Power Steering and its controlled by electronic and it has no relation with the battery and all I can say is that its a complicated system and expansive to repair sometimes. and I might say you should contact the Renault dealer and let them do a diagnostic on it. Good luck
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Renault Expert? Answer questions, earn points and help others
