Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wireless internet I would like to connect a wireless router to an alltel internet card.
  • 550 Answers
Cat 5e cable,
Posted on Jul 26, 2008
Download of driver of huawei mobile connect EC360
SAVES OCUPO LOS DIRVERS
Huawei Ec360 Data Card Cdma Evdo Wireless Pc Alltel
Jan 10, 2013 | Huawei Technologies Ec360 Data Card Cdma...
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
Hello. I own a UM175 Pantech Alltel aircard and I've heard that, using your computer, you can turn the aircard into a wireless router that can be used to connect to the internet with various devices. I...
The UM175 is not an access point itself, you could plug it into a Craddlepoint and then connect your other devices to the Craddlepoint. Testing was down with a UM175 and a Craddlepoint here:
http://www.evdoinfo.com/content/view/2421/64/
If your other devices happen to be computers, you can setup connection sharing and use instructions found here:
http://popewebhosting.blogspot.com/2009/07/share-internet-alltel-verizon-pantech.html
Jun 13, 2011 | Computers & Internet
I wish to use internet for my wii yet my alltel wireless huawei cannot connect directly. ive tried using a lan adapter hooked into the wii and an ethernet cable hooked from that to a router, then using...
Turn on the wii, go to settings, go over until you see stuff about internet... select it and from there add your network, type in your password, put your encryption type, and security like WPA or WEP...... You just have to make that your connection and click test connection if everything goes through select use network and enjoy internet on your wii = )
Jan 11, 2011 | Video Game Consoles & Games
I have an alltel usb broadband wireless card and i would like to get internet on my ps3? Is this possible?
sorry the usb will only put internet on whatever computer it is connected to, it is not a wireless hotspot that something else can connect to.
Dec 03, 2010 | Video Game Consoles & Games
How can i connect an alltel wireless to a belkin G wireless router
i can help you...but i need more information on your network lik model number of alltel device...name of ISP, modem make etc....
Mar 16, 2010 | Belkin F5D7234-4 Router
How can I connect my alltel internet card to my wii system
Unfortunately you cannot insert your USB modem into your Wii and have it recognized. Your Wii does not have the ability to operate plug and play devices in the way that your lap top does. The Wii needs to be hooked up to a LAN (local area network) via a wireless G connection from a wireless router or wireless capable modem, or hard wired to a modem or router with an ethernet cable (looks like a big phone wire).
There is a way to share your lap tops internet connection using an ethernet switch (depending on your operating system). If this is an option that you wish to explore and you have the necessary hardware, re-post asking how to set up a shared internet connection using a computer as a residential gateway. Depending on your operating system this can be done quite easily. You will need a computer with an internet connection (which you have), a 10/100 Ethernet switch, and two Ethernet cables. A switch is relatively inexpensive and the wires are as well.
I hope that this helps you with your problem.
Good Luck!
Jul 28, 2009 | Nintendo Wii Console
My router is connected to my pc. i also have a wireless alltel card for my internet connection. was working perfect but now even when i'm on line on main pc. can't get connected to my laptop and xbox or...
You will need to check your IP address first to see if you have all of the connections. Do this then post your results: Click on start>run>then type cmd. This will get you to the DOS prompt. Then type c:>ipconfig /all
You are looking for two addresses the Gateway address (that is your router) and the DHCP address that is your computers ID. If one of them is missing then the problem lies at your Internet provider not your router. Check if all of your lights are yellow on your router. If one of them is orange then its your Internet Provider. Good luck. Post the two addresses if everything checks out ok.
Jun 07, 2009 | Linksys WRT160N Wireless Router
Setting up router
The Alltel must hook to a wireless source. Your D-link could be that source, but then it needs to be hooked to a source. If you have a wire coming to your house you should hook this to the Wan port on the D-link. Then your computer will hook to the d-link. It then should be setup with codes for security.
Have I confused you yet? In answer directly to your question, yes your Alltel will work with your D-link. But your D-link will then be your wireless source.
Where are you getting your signal from now?
Nov 04, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Help
You can't. For wireless connection on the PS3 you need to have a wireless router hooked up to your modem. Once you have your wireless network hooked up with your PC. You can give your PS3 access and the PS3 will scan for any available wireless networks. Google will help you more if you need more detail on how to set up your PS3 wirelessly.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
