Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
Ice dispenser flap/door will not close properly
My GE Monogram® ZISS420DMSS Ice dispenser flap/door will no longer close tightly and lets cold air out and causes the chute to ice up. The spring is apparently weak and often after dispensing ice will stay open. Even if you reach up there and close the flap, it will not seat tightly.
  • 2 more comments
  • dliang Jun 13, 2008
    We have same problem. The flap/door can not be closed properly and ice fall off sometimes.
  • Rich_E_B Jun 20, 2008
    The repair parts; spring, ice door flapper, and solenoid parts appear easy to remove and replace. However, how do you remove the stainless steel freezer side wrap assembly. It appears to be form fitted and it needs to come off so the door collar kit can be removed to gain access to the ice funnel assembly. I'm afraid I'll bend/damage the SS door covering. Any suggestions on how to remove it from the foam door?
  • Anonymous Oct 07, 2008
    ice dispenser spring
  • jkmirvine Dec 30, 2008
    I have the same problem. Chute constantly icing up. Also water dispenser stops working intermittently. Wondering if it is freezing too.
    New Friend:
    Problem Solver:
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Posted on Dec 03, 2014
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
  • 1122 Answers
SOURCE: Flap on ice dispenser does not open
what make and model?-mike
Posted on Oct 27, 2008
  • 46 Answers
SOURCE: Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Posted on Jun 26, 2009
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
Jun 02, 2012 | GE Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ice dispensor flap is little warped.
the number for ge parts service is 1-877-959-8688. make sure you have the model # and serial number. if you don't have a manuel or if you have one that covers more than one model in it than you have to look for a little black most likely silver plate wich will have that info on it. if it's not on the inside or front of fridge anywhere you will have to pull it out from the wall because it will be on the back of it. hope i helped you.
Aug 15, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ge monogram sidebyside refrigerator
check the flap thats lets the ice come out,i don't think its closing all the way,thats why your getting frost,the water dispenser problem is the water inlet valve on the lower back of frig. and should be replaced,let me know more-mike
Oct 21, 2008 | GE Monogram ZIR36NMRH Refrigerator
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
918 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
