Question about Fedders D Chassis A6D24E7A Air Conditioner
Unit Does not blow cold air
The unit does not blow cold air on any setting. the filter is clean.
  • 95 Answers
Compressor is not coming on or low on freon. Not something you can fix yourself.
Posted on Jun 10, 2008
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
LG ac unit not blowing cold air
check if you still have Freon.
Jul 13, 2014 | Heating & Cooling
I have a ruud ubhc-17j11sfd that does not blow cold air. it blows room temperature air only. the unit seems to run ok and the outside fan runs ok also. The filter is cleaned and the thermostat is set to...
Hello, if the airflow seems good and the unit is clean it is possible that the unit has a low refrigerant charge due to a leak, if you have a thermometer measure the return air and the supply air, tjen find the differance between the two, if it is below 15 then the unit is undercharged and will neec to be recharged.
Jun 15, 2011 | Ruud UBHC Air Conditioner
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
The Amana air conditioner is not getting cold.
when is it the last time you cleaned the unit and changed the filters? it may be working good but you need to maintain the unit...clean all filters and see if you can vacum alll parts especially the condensing unit (you may need air pressure) can you move the unit to outside so you can clean it good? if you can use air or water pressur to clean it after you cover the lectrical parts. Good luck. (save your money this unit need cleaning only)
Sep 07, 2009 | Amana PTH093B35AJ Air Conditioner
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
The thermostat is set at 73... the air conditioner is running and cold air is blowing but the house is currently 82 degrees. I've checked the unit outside and there is no icing. I don't know what to do.
check to see supply air should be around 58F. 20* difference form supply air to return air if 58F my guess unit under sized air filter clean? when was the last time you had the unit tuned up?
Jun 20, 2009 | Heating & Cooling
Soleus MA-9000AH blows hot air
Sounds like the compressor is not running. This model had lots of problems with over heating. It also will never really blow more than a moderate cooling through it. Since you have cleaned all the filters and is still 100 deg, I believe the failure will be the compressor itself or the capacitor.
If you find an oily residue in the drain or on the pipes, it may have simply leaked the refrigerant out. Good Luck!
Jun 18, 2008 | Soleus MA-9000AH Air Conditioner
Fedders D Chassis A6D24E7A Air Conditioner Logo
186 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
