Question about Hitachi 50V500 50 in. HD-Ready LCD Television
No Blue Hitachi 50v500
Ch 3 too much snow to see service menu. Went to digital input - can open service screen (adjust mode LC3X No.1)
then lists r g b settings and High settings. Are at 40 and 400 respectively. Can not move cursor. Using arrow buttons performs button function, not arrow. i.e volumn up, down, ect. Will not adjust with remote. Remote can activeate menu functions. Reset to factory spec. All color settings are mid-line (50). Still no blue. Closest I get is teal.
DOH !
Thanks for your input. Next thought?
    Novelist:
    Champion:
  • 203 Answers
Yes, find a good signal on ch 3 either from a vcr or straight cable. If you change to another input you will adjust set for that input or for that format. Make sure once again that you don't change any settings except the one in question...memory init. You may have to push arrow twice to save changes but I'll check on that. If all else fails you may need light engine.
Posted on Jun 10, 2008
  • Rusty Larmann
    Rusty Larmann Jun 10, 2008
    Actually what you're looking for is a LCD drive board. One last try of reset memory init. after unplugging set for 5 min. is all else I can find on this.
GREEN SCREEN
Try initialize the TV. If works, great. If not, doesn't hurt. Worth to give a try.
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jul 12, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue on the screen of the tv
Try to initialize it!
Jun 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Just replaced bulb and tv picture is still not good. Red tint when tv turns on or off. Picture is to yellow lookin. Just not good color quality. Any suggestions? Hitachi 50v500
You may need to go into your menu settings on the TV, and adjust the RGB colour settings (if it has that option). All colour setting for Red, Green, and Blue (RGB) should be level. Not all TV's allow this adjustment though.
The other thing is that the ribbon cable to the back of the actual screen panel may have come detached just enough to lose some of its signal quality. Although these things are digital, it's still possible for a bad contact to do strange things.
Hope that helps, good luck :)
Apr 06, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv discoloration
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
Aug 29, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Light Engine Problem with my Hitachi 50v500 - Solution
Aug 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 Red Spot
50V500 Red Spot
Aug 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a high definition tv
Jul 25, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red and blue screen on Hitachi 50v500
Jun 28, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red blurred area
I had whole redish/pink screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
1. Enter the I2C Service Menu, be sure the power is OFF.
2. On the front control panel, press and hold the INPUT button.
3. Then press the POWER button for two seconds.
1. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
2. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
3. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
4. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
5. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
6. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
7. Turn the set off-on and Confirm the picture remains in a good condition.
May 14, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
95 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
