Question about Samsung SyncMaster 172N 17" LCD Monitor
Monitor won't turn on.
I moved my monitor to a new location...now it won't power up. No green light, nothing. Checked the cords, swaped with cables I know work, still no power? I packed it carefully in my car and it worked yesterday, today, nothing. What have I done? Help!
  • Anonymous Jun 26, 2008
    samsung DCT-1701S monitor.
    I tried to connect from one computer to another to back up files to the new computer .
    suddenly it wont lit any more .
    I try to put ir on / but nothing happens .
    the cord is giving 12 v normally.
    if I pull the plug and then put it again and press switch on... the green indicator light lit or a millisecond and disappear // what is the problem?
  • 114 Answers
You may have hit a bump in the road which could of made everything shake to much, and the circuit board on the monitor. I suggest going to the company's website and see if you can make the monitor RMA, which you'll send them the monitor, and they'll send you a brand new one for free. but some company's will charge you s and h.
Posted on Jun 10, 2008
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Suddenly today, for no reason, the monitor stopped turning on when the "on" button is pushed. I have checked the cords numerous times, and both the monitor and the computer have been turned off and on...
Try swaping power cables of CPU and monitor. Also, check power button on Monitor. Make sure you have power supply in boards.
Second, try removing VGA cable from CPU and check what you see on screen, if any display like no signal or no vga. That means your Monitor is working but onboard VGA has problem.
Hope this helps a bit to try yourself before taking it to repair center.
May 20, 2010 | BenQ FP71G 17" LCD Monitor
Monitor has no power light or anything.monitor was working fine,turned it off,unplugged it and moved it to another location with the same computer,and now nothing. no power light or anything.checked the...
First place to look will be the power supply section, look for bad caps with bulging top/bottomseal, blown fuse, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
I have a hp pavillion a820n..i was watching youtube quickplaylist 1 day.Then the comp froze. I turned it off,and ever since havent been able to turn it back on.. I tried unplugging power cord and surge...
Check the cable going to your monitor and from the monitor going to the back of your computer, take it out and put it back in. Check also the power cable of your monitor.
Jun 02, 2009 | Computers & Internet
Computer will not load up - frozen on acer start screen?
Are you sure the monitor is plugged into the correct port? Also, check the monitor cable for bent pins. A small move shouldn't make this kind of difference. Eliminate that power strip and just plug the computer and monitor into an outlet.
Mar 24, 2009 | Acer Aspire™ T180 PC Desktop
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
121 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
