Question about LG DH404E Dehumidifier
Water bucket - proper seating
Several hours after I emptied the water bucket and started the dehumidified again I found water coming out from somewhere around the bucket. The dehumidifier continued to operate. It is not the exact model listed above. My dehumidifier has a rear water bucket that the water drips into. It was working ok until I moved it to a different location in my basement. How do I correct this problem.
    Novelist:
  • 121 Answers
Try re-seating the bucket. I have found some LG models that if not seated all of the way will sometimes keep running and think the bucket is not full even when it is. On the models that I have seen do it the problem is usually the left side of the bucket not engaging all of the way. When you reseat the bucket, feel where the bucket meets the dehumidifier on each side and make sure they are even. If one feels like it is sticking out further than the other and you cannot push it in any more pull the bucket out and try and reseat it again until both sides are flush with the dehumidifier. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
It flashes 01 on the display and the bucket full indicator light blinks and it wont run.
If the water bucket has not been emptied the until will not start. If it has, be sure that the bucket was reinstalled properly in the holder and is making contact with the Water Level Control Switch on the back wall, inside of the bucket holder. The bucket should be installed "squarely" into the holder from top to bottom. The bottom of the bucket should not tilt down at the bottom when installed properly.
Hope this helps and thanks for choosing FixYa.
Aug 04, 2011 | LG LHD45EL Dehumidifier
I turn my dehumidifier on and let it run for hours, but when I go to empty the bucket, there is no water in it.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 01, 2011 | LG DH504E GoldStar Dehumidifier
I have a AD50USR1 Dehumidifier. I filled the bucket with wayer, but when i slide it back ito place, the bucket is not pushing that button on machine to operate it. It says to fix or adjust bucket. How do...
Why would you be putting water INTO a Dehumidifier??
The idea of a dehumidifier is to EMPTY the bucket, then the machine takes moisture out of the air, fills the bucket and you empty it again.
Are you sure you need a dehumidifier and understand how they work?
Aug 02, 2017 | Whirlpool Dehumidifier Dehumidifier
Bucket is empty, fan comes on to start up runs for about 2 seconds and shuts system right back off
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 26, 2010 | Goldstar DH504EL Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Leak, non sensing
I have found this issue to be pretty common on alot of LG dehumidifiers. Try and reseat the bucket so the left and right sides where the bucket meets the dehumidifier are both flush with the dehumidifier. The issue usually is you will notice that the left side sticks out a little farther than the right side. If this is the case that means the bucket s not fully engaged with the sensor and it will keep running even when the bucket is full. If you reseat the bucket and both sides are not even try reseating it again until both sides are flush. Once they are flush let t run and keep an eye on it the first time running it like this. You should notice the full bucket light when the bucket is full now. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 09, 2008 | LG DH404E Dehumidifier
LG DH404E Dehumidifier Logo
203 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Michael Van Der...
Michael Van Der...
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
