Question about Refrigerators
Kenmore Model 106.53669300
Need help getting cover on side by side water/ice in the door (Have Ice but not chilled water) Water valve has been replaced !
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
  • 441 Answers
SOURCE: chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Posted on Jul 15, 2009
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Not making Ice. Appears no water entering Ice making chamber even though water is at the door.
The water valve has two coils one for chilled water at the door and the other for the ice maker. Sounds as if the ice maker coil is bad. Hope this helps you to find the problem.
Apr 30, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Just replaced the water filter on our side by side Kenmore 53569202, thinking that may have caused our ice maker to quit working. when opening the door to the freezer, there is a red light blinking twice...
You could have ice in the water shoot which formed because your inlet valve is clogged. The inlet valve is locater in the back behind access cover. Melt the water shoot with a hairdryer and then replace your inlet valve. Fairly inexpensive and easy to change. The reason the water shoot becomes ice is the inlet valve get slower and slower water flow which gives it time to freeze on the way in to the ice maker. Hope i helped, Rate me.
Aug 27, 2010 | Kenmore 53562 / 53564 / 53569 Side by Side...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore side by side refridgerator w/water and ice in door
If there is a lot of water dripping and I guess there is since you had to turn the water off, you need to replace the dual solenoid valve to cure your problem. You did not post your model number so it is not possible for me to say if you have more than one valve assembly in your refrigerator. If you have 2 separate valve assemblies you will need to disconnect the lines one at a time to locate the correct valve to replace. I hope this helped you.
supertechks
Please don't forget to rate me
Jan 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
