Question about JVC MX-J50 CD Shelf System
I have a MX-J50 home shelf system that makes a whirring noise when I activate the panle, but yet works fine except for the dual cassette decks. When I try to engage either side A or Side B of the deck's, Either manualy or by remote, they will not work, but they will make the same whirrring noise! Can anyone offer any assistance or tell me what might be the cause of this problem? Any and all help would be greatly appreciated. Thank you.
  • 3130 Answers
SOURCE: Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Posted on Jul 31, 2006
SOURCE: JVC KD-AVX1 Sirius Just Quit
I had the same problem. My solution was easy, with the car off and deck off find the Sirius connect unit. When you do unplug the large connector. turn the deck on and off once. Then plug the siruis connect back in and turn on your deck. it should work then.
Posted on May 08, 2007
SOURCE: thumping sound from all speakers
Ever find the cause of this? I have the same problem. Thanks Steve
Posted on Jul 21, 2007
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
  • 6966 Answers
SOURCE: Cd stero wiring help
To my knowledge, the illumination wire need not be connected to the JVC KD-G230. Further, other than the 8 speaker wires, the JVC has only:
  • black - body ground;
  • yellow - always on B+12
  • red - ACC/IGN B+12
  • blue w/ white stripe - external amp trigger and/or power antenna
Perhaps this might be of further help to you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
Can this record cd's
Yes it can the blurb for it states: "Full-logic control, dual dubbing cassette deck with CD syncro start recording"
Mar 11, 2013 | JVC MX-KA3 CD Shelf System
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
I have an old JVC stereo model number MX-D301T. There are two issues with my stereo. First, the volume wheel has stopped working. It is stuck on the highest volume setting and does not change when the...
The volume is probably controlled by an IC that does all the work. It most likely has failed. It's unlikely that the wheel is the cause of the trouble, unless it has broken leaving the circuit fully open. But I think that unlikely.
If the unit has not been used for sometime then the second fault will probably due to the belts turning to goo!
Oct 01, 2017 | JVC MX-D301T Shelf System
Sound to right speaker goes in and out, mostly out after a few minutes. checked speaker wire connections. they are ok. switched speakers to no avail. Do I have a bad chip or circuit?
there could be a dry soldering joint on the Right Output of the audio chip inside the unit. As the audio chip heats up, it warms the board up aswell and this can warp it causing the sound to cut in and out.
May 24, 2010 | JVC MX-J50 CD Shelf System
I've had my MX - D301T for about 12 years. We
There are rubber drive parts used in the cassette mechanism, and over time they wear out. Infrequent use can hasten the rubber failure (similar to how a car's tires can go bad if a car sits idle for a long time). An overhaul by a stereo service shop, a good cleaning and replacement of the affected parts, will bring it back to life.
Feb 18, 2010 | JVC MX-D301T Shelf System
Tapes don't seem to work at all. There is only some noise, but
The tapes use many mechanical parts to have it run. I would advise to have the unit opened and inspect it from the inside. Check if the guides for the magnetic ribbon is moving. It is possible that you are hearing is the motor and it may not be driving the other components.
Dec 25, 2009 | JVC MX-J50 CD Shelf System
Cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
Sep 09, 2007 | JVC MX-J900 CD Shelf System
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Stereo component
It has a driving motor belts problem so send it to service provider.
Feb 26, 2007 | JVC MX-D302T Shelf System
JVC MX-J50 CD Shelf System Logo
63 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
