Question about Bose & Wave& Music System
Bose radio/ cd
How do you set the current time as well as stations? you want and can you buy a cord to hook up your ipod
Lost instructions, how do I set time quickly
Posted on Nov 03, 2008
A PDF version of said manual can be found here.
As for connection to an iPod, you need a RCA cable. This is one end that will go into the headphone jack on the iPod, and the other end two connections, one red, and the other either white or black. After hooking it up, just put the WR/CD into aux mode.
Those cables are very cheap on the high street, and are also avaliable from Bose on 0800 614 293.
Posted on Jul 17, 2008
Stations and time are set with the remote as per your user manual.
Posted on Jul 14, 2008
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
I am looking to buy an itouch 8gb. Is the current ipod itouch compatible with the Mirage 14020 docking station?
Hello, yes the current iPods are compatible it is only the older ones that you have to connect to the mirage using aux cord
Jul 24, 2011 | Mirage OmniVibe Stereo Speaker System...
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
I have no radio siegnel from my ipod nano in my bose sound dock
The ipod headphone cord acts as an antenna, and with the design of the nano you can't plug them into the ipod and the docking station at the same time. You can buy an audio adapter cable - a 3.5mm to 3.5mm one; just plug one end into your ipod and the other end into the aux port on the back of your dock. You can then use the radio, as the cable will act as the antenna. I got one on ebay - the cable has plugs on each end which are the same size as your ipod headphone plug. You can also get them in variety stores or electrical stores.
Sep 20, 2010 | Bose SoundDock digital music system...
How do i hook up a ipod to the cd player
Go here:
You can download the manual and specifications.
Oct 06, 2009 | Kenwood KDC-MP232 CD Player
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
4 prong power cord that plugs into back is bent/broken
Don't try using the system as you are at danger of electrical shock - buy a replacement powerpack direct from Bose.
Dec 11, 2008 | Bose SoundDock digital music system...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Bose & Wave& Music System Logo
375 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
