Question about RCA HD65W140 65" Rear Projection Television
L46wd22 rca 46" flat screen
Unusable signal...with audio, only hdtv pics come in, few channels come in black and white only...bought this tv as a display model on clearance- Walmart. Can't get the thing to show a picture, just audio. Need help. Have tried all inputs. Thanks.
  • mariluB Jun 12, 2008
    THANK YOU SO MUCH! BUT WE RETURNED THE T.V. AND UPGRADED TO A 50" SANYO FOR JUST A LITTLE MORE AND ITS NEW IN THE BOX!!! AFTER READING ALL THE REVIEWS ON THE RCA WE DECIDED TO RETURN IT. THANKS.
    Genius:
  • 1,030 Answers
Ok....i know what is wrong with your set.. it is a small (very small micro fuse. rca has issued bulliten to service centers on the problem.. getting the fuse and describing where it is then soldering might be the difficult problem here.. but let me give it a try. it is located on the main signal board in a shelded covered board called the main signal board. The fuse, 1C33,is located approximately 2 inches behing the tuner The surface mounted part has various markings on
the original part from “105” to “F”
and is located below the board marking “7C32'
Replacement fuse #275819 can be placed directly over the top and soldered to the ends of the existing fuse
to lessen the chances of damaging the board traces.
all that being said.. this is some trick soldering.. and unless your a tech i would not recomend such a repair.. i cant speak for all shops but such a repair is not that difficult for most techs and cost about 125 to 200. So good luck and let me know how it go's or if i can give any more detailed info
Posted on Jun 10, 2008
WE JUST RETURNED THE T.V. WE READ THE REVIEWS ON THAT RCA MODEL AND THERE WERE TOO MANY BAD ONES. WE UPGRADED TO A 50" SANYO THAT IS NEW IN THE BOX AND ONLY COST US A LITTLE MORE.
Posted on Jun 12, 2008
RCA L46WD22 LCD tv (3 year-old unit)...No picture, tried unplugging for a few hours to ''re-set'' the computer...nothing, tried to view a DVD, nothing, just a black screen with the ''unusable signal''...
The back lights inverter is working because you can see the "Unusable Signal' on the screen, if the inverter is dead, yoo will see nothing on the screen at all.
If the T-CON (LCD controller) is dead, you will see just gray glowing screen with no pictures or text.
You may have problem with video processor in the main logic board (tuner, audio, source selector).
Parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L46WD22+&stock=all&limit=100
This is going to be difficult repair since you do have a way to try out the replacement board to be sure that is the problem. RCA service person has that advantage of parts in stock to try out.
I estimate the board from Jimmy to be about $150, from RCA will be twice as much, plus labor.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 28, 2010 | RCA L46WD22 Television
I am having issues with my RCA L46wd22yx5. First cable is on channel 3. that channel keeps saying unusable signal. Video 1 is the DVD player. Same thing..Video 2 is the Xbox 360 same thing and the HDMI1 is...
Check to make sure that the individual cables are connected to the corresponding channel. For example, DVD player is connected to the "Video 1" output on TV. On the back of your DVD, the cable is plugged in the "out" output, going to your TV the cable is plugged in the "in" output(red, white, yellow) Are you using an RCA cable(red, white, yellow) for the units?
May 13, 2010 | RCA L46WD22 Television
Cable has pic and sound dvd ps2 only has sound no pic. says no signal
try hooking a rca yellow video cord to the adjacent plugs 1 from player to tv video in right next to ps2 input. ps2 is for audio only.
Nov 07, 2009 | Samsung LN46A650 46 in. LCD HDTV
When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Take the back panel off and look for a smd fuse with an F on it. Middle panel in the upper left corner, it is about the size of a tip of a pen. We used a copper wire to make a jumper. Works great now!!! We also noticed that there we some loose pieces and we pushed them back in and now the buttons on the side of the TV work.
May 17, 2009 | RCA L37WD12 37 in. LCD HDTV
I am having a problem with an RCA tv..unusable signal.
make sure that you have it set to the right input signal source and that your source is working properly. if so then yeah, you need to replace the fuzle modulator.
Mar 11, 2009 | RCA L46WD22 Television
Rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Jan 03, 2009 | RCA L37WD12 37 in. LCD HDTV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
May 11, 2008 | RCA L37WD12 37 in. LCD HDTV
Unusable Signal
Hi. What you need to do is plug in a cable or Antena in its place, and reprogram the channels. if you did that, then try to use a VCR or DVD player and install it using the RCA cables. Install the cable to the DVD or the VCR. If nothing works, My TV has a crack in the LCD. I'll either sell it to you, or buy yours. Let me know. Thanks.... email me to hajum30@yahoo.com
Thank You...
Sep 29, 2007 | RCA L46WD22 Television
RCA HD65W140 65" Rear Projection Television Logo
468 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
