Question about Samsung HLP4663W 46" Rear Projection HDTV
Color wheel have noise in samsung projection....sounds like color wheel..what would a tv repairman normally charge to repair?
    President:
  • Samsung Master
  • 1,779 Answers
About $350.00
Posted on Jun 15, 2008
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Buzzing noise, just replaced the lamp, pulled and ...
The colors wheel was defective,was spinning off of it axis that was where the buzzing noise came from.Now the colors wheel it totally dead,that why u not hearing anymore buzzing noise,and not getting a picture.Hire a tv repairman for this job.Replacing DLP tvs colors wheel is not easy,if u have no machanical's skills and never done this before.
May 21, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud motor noise coming from back of television upon powering on
This DLP tv have a colors wheel,it worn out and it spinning off of it axes motor.U have no colors.U hear grinding and loud buzzing sound or loud squizling.All this indicate colors is defective,and must change.Hire a tv repairman for this job.Because u have no machanicals,don't atemp this by buy the colors wheel,tries it to do this and replaced it ur self.Must take out many machanical's parts,even get to the colors wheel to rreplaced.Many people though is was easy they tries it and have problems or fail,than cause some else in the tv to go wrong.End up costing them more $$.And the Tv Tech. don't like fixing people mistakes and blunders.
May 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
The bulb has been replaced within the last 3 months and everything has been working fine. When I turned the TV on just now there is a buzzing sound sounds like a motor is running and continues to run for a...
Ur colors wheel it dead.It spinning of it axes.The noise u hear it the grinding of the colors wheel.There no colors,big buzzy loud noise,or grinding noises.In any kind of DLP tvs that produce the last 10 years they all have colors wheel's.Hire a Tv repairman for this job.Because it require alot of taking out of machanical parts,even can come to the colors wheel part to replaced.Many people made a mistake think it was easy,cost them alot more $$,because tv's tech. don't like fixing other people mistakes,and blunders.Give them a head aches tries figure out what the customer did.
Apr 10, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Loud buzzing noise and no color. Does this mean the color wheel is bad. Thanks
Yes,the colors wheel is worn out,U have no machanical skills,hire a tv repairman to change this.Require take out many parts before can even to get to the colors wheel,to replaced.
Mar 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Humming
This sounds like a problem with the color wheel - seelinks below.
Samsung Color Wheel Replacement Guides.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Or try this link:
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
If you find that these links helpful be sure to respond with a rating. Thanks for using Fixya!
Dec 27, 2009 | Televison & Video
Samsung DLP HLR5667wx/xaa. All sudden loud noise non stop
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set.
Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
Sep 05, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
