Cluster ubuntu towers toghether.
I want to have each computer act as a seperate Core. I know it can be done as it was set up before but I can't seem to find any info on it at all
  • 981 Answers
Yes, there are tons of cluster solutions out there, and you should definitely check out the excellent documentation there was out there for Mosix. That software has been brought into other kernel projects at this point, and is available as modules or compile-ins. Just refer to the kernel documentation first and consider the cluster management software independently from Ubuntu. You are welcome of course, to use Ubuntu forums to help flesh out the cluster documentation you yourself happen to need.
Be sure to make economic use of electricity, and to call processors CPUs or processors, not cores (which is a precise term for an almost-independent CPU; there is more to a 2-260 core CPU than just those cores!)
Posted on Jun 10, 2008
I want to know if the Canon imageCLASS MF3240 is a postscript printer? Other question is there any way for the driver to work under ubuntu 12.04.5?
do you have instruction manual ?
you may be able to print from the printer a settings summary which may show the language the printer is expecting ./
there may be a way for a windows driver to work in ubuntu it is done by either finding a ubuntu driver for the printer (which seems really hard to find) or mucking around using ndiswrapper utility to try and manipulate a driver to work in ubuntu.
sourceforge.net/projects/ndiswrapper/
Oct 26, 2015 | Canon imageCLASS MF3240 All-In-One Laser...
No boot
Turn on a working computer with its keyboard plugged in and test if the keyboard is working properly.
If it is, shut down that computer, unplug the keyboard and plug it into the system that is suffering from the missing "NTOSKRNL.EXE" file.
Turn on the system to see if the replaced keyboard resolves the problem.
Press the "F8" key right after the system initializes the boot sequence and before the Windows logo shows up to bring up a menu of boot options.
Choose the "Last Known Good Configuration" option with the arrow keys and press the "Enter" key.
Insert your Microsoft Windows installation disc.
Restart the computer and press the "R" key on your keyboard once you reach the "Microsoft Setup" menu.
Choose the operating system that you wish to repair, type in your admin password when prompted and press the "Enter" key.
Type "bootcfg /rebuild" and press the "Enter" key to rebuild the Windows "boot.ini" file, which may also resolve the issue.
Type "chkdsk /r" and press the "Enter" key to scan the entire hard disk for errors.
Type "exit" and press the "Enter" key to exit the "Recovery Console."
Restart your computer and see if Windows boots properly.
Feb 17, 2014 | Computers & Internet
Have powespec G214. Has i7 but only one core is running. would like all
Ubuntu will NOT run on a muti-core motherboards properly. You should've just installed Windows 7 Ultimate 64-bit with SP1 or Puppy Linux Live.
Feb 01, 2014 | Powerspec G214 Desktop Computer; Intel...
Instruments not working on 1997 Jimmy, after replaceing the heater core
Check, you may have a connection to the cluster not fully plugged in. It's got to be at the cluster-the instrument panel.
Dec 24, 2013 | 2004 GMC Sierra 2500
Graphics driver for fujitsu laptop in ubuntu
before we can offer any help, we need to know the model number of the computer as different models use different graphics chips.
Jan 19, 2013 | Fujitsu Lh531-b960 Laptop 14hd...
Will this tower be useful as a home computer?
It will if you run Linux on it. I suggest one of the Ubuntu flavors. Investigate the various pros/cons of Ubuntu/Kubuntu/Xubuntu, etc., then download for free and install.
Jul 24, 2012 | Dell Optiplex 745 2.13GHz 2G RAM 500GB...
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
Hi All, My problem is with my computers, we are in an area in far north Queensland where we have a lot of power outages, we had one yesterday which shut everything down and now I cant get either of...
The first thing I would try, if the monitors have multiple inputs - would be to connect a regular VGA cable to the monitors and see if this solves the issue. If that fails try the monitors on other computers to see if it may be damaged.
Another idea, try a different video card.
It's also possible that your OS is causing the problem - one way to check this is to download and burn to disk the Ubuntu OS. If you set your BIOS to boot to the CDROM it will run the OS without affecting your Windows (I assume) installation.
If the monitor works under Ubuntu at least you know the monitors aren't damaged.
Power surges, blackouts and brownouts can be deadly to a computer - if your area is subject to a lot of these, a quality UPS would be a worthy investment.
Dec 08, 2010 | Computers & Internet
New HP keyboard & Mouse not working
I solved this problem by
1taking off the tower cover
Jan 22, 2009 | HP P2360AA Keyboard/Mouse
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
Jul 26, 2008 | Excelstor Technology J880 Hard Drive
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
