Question about Audiovox ACD-24 CD Player
Release cd my cd is stuck inside the cd player and will not come out. the cd player says there is no cd in there but i am sure there is.
  • Anonymous Jun 10, 2008
    Audiovox ACD-24 auto AM/FM CD player came with the car. Radio works fine. First time I put an audio cd in it played fine but would not eject the cd. Pressing the eject button caused the word "eject" to show on the screen for a few seconds then it commenced to play again. I tried the eject button maybe 50 times on two days to no avail. Then on the third day it worked. Visual inspection showed no obvious problems. Is there a mechanical ejection procedure using a paperclip?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Your CD reader must be damaged. You will have to manually take the CD player out of the cradle, and take it apart. This should be easy. Once you have the top off the CD player remove your CD and put it all back together again. You can by lens cleaning CD's from walmart, K-mart..any mart. Run that through and see if it helps. Once CD player is back in the car, hit eject to make sure the player knows it has no CD in it anymore.
Posted on Jun 10, 2008
    Genius:
  • 1,224 Answers
Not nessecarly take it apart make sure power is on
on the front under the plate there is a little pin hole you push in with a straightened paper clip all cd players come equipt with this it pops the gears and pushes disk out you will have to use little pin and its usually positioned right side under cd slot
or you can disconnect the power and connect it again at battery this has helped some times
or take old aol cd push in gently on other cd this could release the cd
The CD is stuck inside my machine. How do I take it out?
Most CD players have a small hole where you can insert a straightened paper clip to release the lock.
When the lock is released, the tray will come open only slightly.
When it does, pull gently on the tray to get it open enough to remove the CD.
These instructions should also be in the manual.
Jul 25, 2015 | Audio Players & Recorders
Cd stuck in cdr-220, single cd, no mag, is there a manual release?
Nope, cute the power and remove the player...access it from inside at the rear and push the cassette foreward.
Jan 13, 2013 | Cars & Trucks
I have a Power Acoustik PTID-7000NR and the cd is stuck and will not come out. It plays fien and everything else works. But the CD will not come out. Any suggestions? Thanks!
you may have two cd`s inside take the radio out and take it apart. inside the radio there is a realese for the cd tray but you have to have power to the unit for it to work. eject the cd from the front then hit the release on the inside its a little tricky but you should be able to find it
Sep 20, 2011 | Power Acoustik PTID7000NR Car Video Player
How do I remove a stuck 6CD changer magazine?
Our Bose has a 5 CD player, So, I'm not sure if this is the same for your base unit, but here goes. You'll need: a bright light and a small screwdriver that reaches inside the chassis (or equivalent).
1. Disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Using a bright light, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. When you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in teh player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Feb 19, 2011 | Bose Lifestyle 20 System
I put a cd in the player and its stuck inside. how do i get it out without smashing the player?
Possible that there was a fault in the CD , maybe warped that has caused the CD to get struck inside. It can also be due to the failure off the loading mechanism of the player.
Hence you will require the hexahead tools to remove the mechanism so as to retieve the cd from the struck up mechanism.Remove the lid , then observe the mechanism , remove the mounts and release, thereafter check if the motor works , if not the loading motor drive IC , motor or the processor can be defective. ,
Oct 30, 2010 | Philips HTS-6500/37 System
2004 Malibu CD is stuck inside player
can you remove the CD by opening up the face cover and using a pen or pencil push in on the release hole most are equipped with this feature if not maby tweezers and grab a hold of the edge of the CD itself and help it out while in eject mode
Sep 08, 2009 | 2004 Chevrolet Malibu
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Philips 642 problem
when mine has frozen up i push and hold the power/standby button for ten seconds then release then push it again and it comes on and opens as usual.  or do you mean the disc is stuck in the machine after the door opens?  maybe open the machine it could be inside.
Dec 23, 2007 | Philips DVP642 DVD Player
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Cd player
hi the gentle macanizem is bad probaply a thooth or a little wheel whats the qustion? you can spry a lubricant spry inside (through the little holes ) NOT ON THE LASER EYE!! it will smooth things out a little bit good luck
Dec 27, 2005 | Emerson NR303TT CD Shelf System
Audiovox ACD-24 CD Player Logo
166 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
