Question about Whirlpool Dryers
Control locked... how do I turn off this function to have my dryer work again.
    Genius:
  • 1,028 Answers
Look for a button with small lock icon underneath it hold button down for 3-5 sec
Posted on Jun 11, 2008
2 Suggested Answers
  • 949 Answers
SOURCE: the status reads "control locked" and the dryer will not function
Try pushing and holding the 'End of Cycle Signal' button for 4 seconds. Let me know if that works.
Thanks!
Posted on Jun 14, 2010
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
The machine door wont open after it finish the wash cycle
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Dec 07, 2014 | Indesit W 123 Front Load Washer
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
The status reads "control locked" and the dryer will not function
Thanks!
Jun 14, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control panel not working after "function lock" buttons pressed
MD,
Hit the up and down again and do away with the Function Lock.
Tom
Apr 23, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool YGEW9250PW1 Electric dryer control locked problem
I had the same problem, but my husband, who is an engineer, figured out that if you pull out the light bulbs that are not reading the correct volts on his volt meter, the control lock light will shut off and the dryer will start working. If you do not know how to do this, you can always buy a new control panel. I know this sounds to simple to be true, but we have bought several new "brains" (control boards), tried unpluging the dryer for days at a time, had an certified whirpool technician come out (who recommended buying a new control board), and nothing worked.
Sep 01, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
