Question about Samsung Televison & Video
After I have been watching my ln-t4081f for a while and I turn it off, when I turn it back on again all I get are lines on the screen and no picture. I have to let it "rest" for quite some time before it operates properly.
    Genius:
  • 2,035 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Posted on Jun 10, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung LN-T4081F Television just stopped working. No picture but TV TURNS ON.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 25, 2015 | Samsung Televison & Video
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
SamsunG MODEL LN-T 4671F 6 HAS GREEN LINES IN PICTURE CAN STILL WATCH TV.
The screen has failed. It can't be fixed, but you can get a new screen fitted at the shop.
Oct 12, 2012 | Samsung Televison & Video
My Samsung 42" LCD used to turn on quickly, now it takes a LONG time for the screen to show anything. It looks like it turns on, turns off, turns on, etc. 7-8 times before finally staying on--almost like...
Ageing capacitors usually causes this sort of problem. They change value going low capacity etc. A replacement flourecent display board may likely fix it as the display is taking too long to come on.
Oct 16, 2010 | Samsung LN-T4081F Television
The sound suddenly ceased on my television--is there a way to reset the tv and see if sound reboots as well?
Go to menu reset the audio,back to factory setting.Should work,not than ur tuner signal board is dead.
Jan 12, 2010 | Samsung LN-T4081F Television
Turn tv on, all lines no picture
T-con board ro related cable problem.
You should check aboves, later iIf can't watch the TV because of the lines.
Dec 28, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
We have a Samsun LN-T4071F LCD TV. The screen is all white and colored vertical lines. We disconnect the HDMI cable from the Dish box and the screen stays that way. We turn the TV off for a couple hours...
Do you have warranty on this unit?If warranty available contact servicer.
From your description problem is in the Digital board.
Replace digital baord.
Dont forget to Rate!
Good Luck
Dals123
Oct 22, 2008 | Samsung Televison & Video
Televison & Video Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
