My Pioneer Inno wont stay powered up. - Audio Players & Recorders
    Brigadier General:
  • 6,966 Answers
This is a known issue with Pioneer Inno. Pioneer has received so much complaints including lack of battery-life that a firmware upgrade has been released. Said upgrade is supposed to fix a multitude of issues/problems including extending battery life. The firmware update may be downloaded from here. Update is performed with the Inno plugged into a PC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Your battery could be at end of life depending on how long you have had it. I know pioneer are pretty good with warranties so if you have had it for 12 months or less contact pioneer and ask them if its viable for a warranty replacement. Or even take it back to the place you bought it from. You may be able to take it to an electronics store to test your battery charge capacity as well.
Pioneer Inno
Perhaps memory is full
Jun 23, 2008 | Audio Players & Recorders
Pioneer Inno - Powers on, great signal - but audio or pad data!
I'm assuming the power button it not in 'hold' position, and you have the volume turned up, and/or on the correct frequency with the adjoining radio?
May 27, 2010 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer Inno shows loading
Not any more help here than with Pioneer. Not sure satellite radio is the way to go if you have to replace the radio very couple of years!
Sep 02, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno
The problem is caused by a glitch in the firmware that came on your Inno. It can be easily fixed by downloading a free firmware update at http://fwupdt.xmradio.com.
Aug 29, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer Inno
Rick,
You can connect the inno via the home doc and the provided cable in the home kit. You may have to connect to an unused component on the receiveer (VCR comes to mind)...You move the VCR source on your receiver and you should be good to go.. I have a Pioneer Elite receiver but Pioneer makes no cable to connect those two ..no matter... I wanted to control the Inno from outside the receiver's controls..
Sam
Nov 23, 2007 | Pioneer Audio Players & Recorders
Pioneer inno
I have the same issue. I was told a firmware upgrade will fix this issue
Nov 05, 2006 | Pioneer XM2go Inno Satellite Radio...
94 people viewed this question
 Grubhead
Grubhead
