Question about Protron PDV-768 Portable DVD Player
Is there an external battery pack that would work with this?
The pdv-768 has no internal battery and I would like to take it on a plane and need an external power source but have yet to find something for this particular model. Any suggestions? Thanks so much!
Rene
  • rbecker5 Jun 10, 2008
    I am aware of external battery packs but cannot find any to work with this particular model. I called the company and was told they will not work with this model but I find that very difficult to accept as the description of this player at amazon states there is an optional battery pack. Unfortunately, no other info is available and extensive research has turned up nothing except other frustrated owners.
    Brigadier General:
  • 6,966 Answers
There are on the market external battery packs (rechargeable) specifically designed just for this purpose/DVD. You have of course to specify that voltage and current requirements as well as the type and polarity of the power plug. There are universal models that normally fits most models of DVD, something similar to this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
  • Louie  Role
    Louie Role Jun 10, 2008
    Hi again,
    Appreciate the post back.
    If none is available on the market, why not make your own? If you would look over the AC adapter of your Protron PDV-768, pls confirm that the output is 12VDC 1.5Amps. This is enough information to configure the external battery requirement. Additionally, this particular model has an automobile adapter which confirms its 12VDC requirement. As to the type/size of the plug, most electronics store carry generic and some even could be purchased with wires attached/pre-soldered. The polarity is a matter of using a DVM on the original adapter and determine if it is center positive (most likely) and simulate with the purchased plug/wire. The battery could be any external battery pack capable of supplying the 12VDC/1.5A. An ideal candidate would be replacement/generic battery packs for laptops. Recharging the external battery pack is a matter of using the original adapter or purchasing another one specifically to recharge the battery pack. Of course the charger would have to have a complementing/mate jack for the plug with correct polarity.
    Genius:
  • 1,226 Answers
You can try some external battery..Please consult vendor or the battery substituinal manual. and then use voltage regulator to extrct voltage needed by your DVD.
melnavs
  • Emelio Navaja
    Emelio Navaja Jun 11, 2008
    Hello Again,
    If this comes into problem, You should identify the voltage power required by your player that with use of some twick like voltage regulator which can be made electronically that most of the electronic tech can make this power supply to supply the player from the DVD +inverter(to regulate the supply). However if this hard you to find the maker. you have no option except make your player only at home.
    Genius:
  • 2,035 Answers
You can batteries for the model which is sold separately to while traveling , if you have direct dc slot on the player you need to buy adapter pins which available on line and most of the planes laptop power ports which ca be used to power your player......
goodluck
I need to replace my battery pack for my dvd player model pdv-709 model bat-09 do you no where i can get one
try batteries plus.
They carry just about any battery made!
Hope that helps you
Feb 23, 2011 | Durabrand PDV-709
Screen won't work on external monitor
Most laptops have a "video" option:
* output only to internal screen
* output only to external screen
* output to both screens
Be sure to select the 2nd or 3rd option.
Also, reset your internal screen-resolution to 1024 by 768;
hopefully, your external screen will support this resolution.
Jan 05, 2010 | Acer Computers & Internet
How do i buy a battery for my Protron PDV-288
You could purchase the same from :-
http://cgi.ebay.com/PROTON-PORTABLE-DVD-PLAYER-RCHAGBL-BATTERY-PACK-PDV-288_W0QQitemZ370277580972QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item56364380ac
As of now, it is in stock with them and the cost id $16.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Replacement battery for Protron PDV-288 portable dvd player
when buying batteries, just bring your battery as sample or have a tech to check you unit or battery substitute if ever you can't find one.
May 16, 2009 | Protron PDV-228 Portable DVD Player
How to open and operate protron pdv 768
searched the web (google) and found a site that had the item for sale with pictures of it opened. once you see it open you can tell how to open it. inside are similar controls to a TV remote/dvd remote. rest was simple! thanks for your help though :) -r-
Dec 27, 2008 | Televison & Video
Spectroniq PDV-768
uk dvds are formatted in PAL
us dvds are NTSC
find your settings screen (usually has a wrench to identify it)
Nov 02, 2008 | Spectroniq Protron 7'' TFT LCD Portable...
Spectroniq pdv 768 region code
  1. Open Device Manager.
  2. Double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
  3. On the DVD Region tab, make the appropriate changes
cheers
Sep 17, 2008 | Spectroniq Protron 7'' TFT LCD Portable...
Wrong region code
I also have the same problem,if you find a solution could you please pass it on charlie.75@hotmail.co.uk thanks
Nov 30, 2007 | Protron PDV-768 Portable DVD Player
Power supply for the 2nd screen ??
If you are not using the car power adapter that came with your PDV-768 for the 2nd screen, you are likely running into the possibility of "reversed polarity" with the power adapter you are attempting to use. This can & often will cause a problem with your unit.
Nov 28, 2007 | Protron PDV-768 Portable DVD Player
Protron PDV-768 Portable DVD Player Logo
43 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
