Question about GE Refrigerators
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
    Problem Solver:
  • 8 Answers
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Posted on Jun 10, 2008
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Black Maytag Side by Side MSD2756AEB 7+ yrs old? Won't stay cold...
Your condenser where the heat is removed from the refrigeration system may be plugged with dust. The condenser is more than likely located in back of the refrigerator behind a removable panel. Remove the panel and clean it out. Reinstall the panel after you have cleaned the condenser.
Check the back wall of the freezer for frost buildup. If there is frost buildup on the back wall it indicates that there is a problem in the defrost circuit.
Note: The proper term is "More mature individual" , not old.
May 31, 2008 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
