Question about Sharp R-308H Microwave Oven
Emerson Microwave Oven and Grill MWG9111SL
I cant heat anything up the upper grill part fills hot but will not heat the food what do i do
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kgjlkglj
Posted on Sep 30, 2010
How to make rice in mwg9115sb?
I hope this will help I have a Panasonic which it gives you a guide for rice :
Basmati 250g low 10-12 mins
Easycook White 250g on High
Use 600ml (1pt) to 800ml 1 half pints boiling water. Cover and place on turntable.
May 31, 2014 | Emerson MWG9111SL Microwave Oven With...
Shut itself off and wont turn back on (totally dead) on a good electrical outlet
maybe the fuse blown inside the oven if you are lucky... try to look at it but there's a reason why the fuse blown usually a short circuit in one of the parts...
Dec 09, 2013 | Emerson MWG9111SL Microwave Oven With...
Shut itself off during cooking and wont turn back on
I had a similar problem with a different make of microwave oven with grill and, on taking the cover off, found that a normally closed thermostatic switch (little round thing, with tab connectors - one of three, in my m'wave) had burnt out. I suspect that this switch had a manufacturing fault which took some time to show up. On a certain website with a 'buy it now' option I was able to buy a pack of three of these parts for very little money, from China. The temperature rating of these switches is marked on the casing.
I need an owner's manual for an Emerson Microwave Grill - Model #MWG9111SL. Mfg. July/08. Do you know where I can find one?
It's here:
http://www.emersonradio.com/owners/MWO%20manual/Manual%20of%20MWG9111SL/MWG9111SL.pdf
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Sharp R-308H Microwave Oven Logo
143 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
