The touch screen will not function.
I can turn off/on mute adj. vol. but not touch pad funtions. thanks, tryed to program one forall upc-3220 wiyh vcr and could not find the right code
    Brigadier General:
  • 6,966 Answers
Without knowing the make and model of the VCR, could not locate the code for you. You may want to try with the manual should you need one here.
Alternately, codes for most manufacturers may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
    Genius:
  • 1,226 Answers
kindly unplug from the wall outlet to let reset the unit and then plug it on then test.
Targa Visionary LT 3220 television is stuck on mute. tried pressing mute button on remote but nothing happens.
Unplug the TV for 5 minutes and see if it clears. Is there a mute message icon on the TV screen (picture of a tiny speaker with a line through it)? It turns off anytime the volume control is touched automatically, so if that doesn't happen you have a problem with the TV itself.
Aug 18, 2016 | Televison & Video
I need to program my zeinth tv with the one for all upc-3220 remote
Codes to check with Zenit TV are: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Sep 30, 2012 | Televison & Video
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
My volume touch pad does not work correctly with my volume icon on my desktop. By this I mean: The blue lights that turn off and on when you turn down or up the volume do not work correctly. I will have it...
yes mine did that too, i believe that it has something to do with messing with the volume before the drivers load, that means that if you mess with the volume in a different operating system, during boot, at the welcome screen, or during shutdown....you miss align the pad lights with the OS volume level, so next time you shut down drop your vol. in the software to ZERO, then on startup get the touch pad to ZERO, (not mute) before windows fully loads and you login
May 11, 2009 | Acer Aspire 6920 Notebook PC
Innovage -lcd touch-panel phone cant shut ringer off or lower
loudness control - press hands-free once, and then VOL button to select the loudness level from hi to lo then press the hands free to confirm setting. press VOL button to exit and to return to the main display screen. I know there is no switch to turn the ringer off. I tried that my self. this is the only setting they do have a far as I know. good luck - Sherry
Mar 21, 2009 | Innovage Touch-panel Phone 1502084
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
N73: difficault to open message ,dont ring when called,vol adj.
restore your factory setting or hard format your fone,,, to hard format, pres and hold *3 and the send key for 2 mins and ask someone to help switch it on while you still hold the three keys together,,thanks
Dec 30, 2008 | Nokia N73 Cellular Phone
One forall universal remote urc3220
I can help you with your URC-3220 Universal Remote Control issues.
The URC-3220 codes for Sharp TV's are: 0093, 0165, & 0688.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Jun 07, 2008 | Sharp 25R-S100 25" TV
Annoying screen pops up when i check my voicemail
No the is not but you can reduce the sensitivity of your phone. Go to main menu-> then to settings and tools-> then to touch keypad or number 7-> then sensor level or number 1. There you can adjust the sensitivity. The lower the harder you must push the touch pad though.
Jul 24, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
