Panasonic cf-29 Touch screen not working
Touch screen has workrd fine but now will not work. Touch pad is fine, device manager says mous is working fine.
  • 1 more comment
  • correll_kim Aug 13, 2008
    Yes same problem
    My touch screen on my Panasonic CF-29 has quite working and unable to re calabrate. Also evry time the unit gets bumped in the slightest a window pops up regarding certificate information. I have tried to uninstall/re-install the drivers and tried to re-calabrate.
  • jksmith Jan 03, 2009
    My touch screen became enabled. How do I fix it????
  • Anonymous May 14, 2009
    uninstalled and reinstalled driver, no luck... wont work..
Hi!
I have a cf29 and the only driver that works for me I found it at the Fujitsu.com website,
http://www.fujitsu.com/us/services/e...s/drivers.html 4 and 7 wire touchpanel use the same driver, Good luck!!
Posted on Mar 04, 2010
Go to Telrepco site (www.telrepco.com). We are a Panasonic authorized toughbook repair center and haver a replacement touchscreen solution for $300. Check it out Call 1-800-537-0509
Posted on Jun 30, 2009
    Genius:
  • 2,028 Answers
May be a conection problem. I had a cf72 that the conection had come loose at the motherboard. If its not the conection it may be the scvreen itself.
Posted on Jun 10, 2008
How to disable mouse pad double tap
On all Panasonic Toughbook models, if the Touchpad driver is
properly installed then you can disable the "TAPPING" feature.
Check under device manager. If the driver says PS2 Mouse,
then you need to locate your touchpad driver. Otherwise
locate the advanced setting under MOUSE under the control
panel and find "TAPPING" and un-check to disable feature.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 10, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Touch screen doesnt work on my cf-29
Hi Jade. If you have a windows XP in your machine Try to upgrade to win7 or win 8 since windows xp doesn't come with touch screen drivers.
Jan 23, 2014 | Panasonic CF-29 (CF29NWQGZBM) PC Notebook
Cf-29 replace mouse pad
Panasonic Toughbook CF-29 series of Notebook PC's, Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-panasonic
Go to the line that starts with CF-29N3LGZBM, and CF-29NTQGZBM
For the CF-29N3LGZBM the disassembly starts on Page 19, and for the CF-29NTQGZBM.
I don't see the difference, but perhaps you will between the two.
To me a CF-29 is a CF-29
You disassemble from the Bottom up. Remove Base Enclosure,
http://www.youtube.com/watch?v=-ITIcLckkIw
(No narration, just 'elevator' music)
Remove Mousepad,
http://www.youtube.com/watch?NR=1&v=8BJRwBwCKhg&feature=endscreen
A) Remove ALL power. Remove the AC adapter (Charger), and Battery
B) USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Wear an ESD wrist strap, and your laptop is safe from Static.
(From you)
Don't wear one, and use your laptop for an expensive paperweight.
Average cost is $3 to $6. This is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of an empty open desktop computer case. (I don't feel an Anti-Static Mat is warranted, and can explain)
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or perhaps a large metal knickknack. (Unpainted)
You can't discharge Static by touching the metal frame, of the laptop.
Doesn't work that way. (ZZZZZzzzzap! Goodbye computer )
C) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws!
Advise do NOT mix them up.
D) Take photos, or use a video cam; if available. Use good lighting.
Make notes, and/or drawings if you wish.
It's nice to have a Personal record, as well as a Service Manual, and pictorial information.
It's nicer to have YOUR method YOU used, along with the above.
Jus sayin'.
No.1 Philips screwdriver
Put everything back just LIKE it came out. Don't pinch any cables.
http://www.bobjohnson.com/_store/Display_Buy.asp?prodID=CF29MOUSEBOARD
http://www.ebay.com/itm/Panasonic-Toughbook-CF-28-Touchpad-Palmrest-/290787254286?pt=LH_DefaultDomain_0&hash=item43b445600e
http://www.ebay.com/sch/sis.html?_nkw=Panasonic%20Toughbook%20CF%2029%20Pentium%20M%201%2030Ghz%20512%20MB&_itemId=151000412795
Wow! Sellin' kinda cheap! Looking for parts I ran into this.
Not advertising. Besides, it isn't allowed on here anyway, lol!
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Panasonic Toughbook CF-29 Notebook
Panasonic CF-29 touch screen do not work
Do you have the driver for it? Try install the driver on your PC and see.
Apr 03, 2012 | Panasonic Toughbook 29 Touch (P/N...
Touch screen do not work
Have you checked under the device manager in to make sure that all your peripherals are recognized or enabled in the bios
A: Activate Touchscreen in Bios
B: Reinstall all drivers
C: ensure OS is recognizing the peripherals.
Good Luck
Touch screen dose not work
The CF-30 is equipped with a resistive touchpad. It is designed to be more rugged and last longer than a capacitive touchpad. Applying pressure and keeping your finger on the pad longer while you move your pointer will help with speed. Pointer speed can also be adjusted under mouse properties in the Control Panel.
Find the complete model number on the bottom of your laptop 'CF-30XXXXXXX' and locate the correct driver by following the link below. Once you've downloaded the correct driver, extract the file to a new folder and run the Ftsetup file. (accept all default settings). You may need to restart the Toughbook.
http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
Try reinstalling the touchpad and/or touchscreen driver.
Dec 29, 2011 | Panasonic Toughbook CF-30 Notebook
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Mouse cursor jumping uncontrollably all over screen.
Your touch pad drivers need to be installed. Power off the laptop. Install an external mouse, power back on and install drivers. When finished, power down, remove the external mouse and reboot.
Dec 29, 2008 | Panasonic Toughbook 29 Touch (P/N...
Computers & Internet Logo
6,610 people viewed this question
David Payne
David Payne
