Question about GE Profile JTP18 Electric Single Oven
GE JTP15 oven shuts off
We have a GE JTP15 built-in oven that has intermittently shuts off during use. It heats up to desired temperature, everything is fine, you put food in to bake, and then wa-la.... without warning it shuts off. No beeping noises or flashing error code as I have read others mention, it just shuts off and has cooled down by the time I realize it's shut off.
We bought this house last summer, and we are under a home warranty with AHS. The first time this happened, I called them and they came out and said there was nothing they can do, because they cannot recreate the problem. Indeed, a month can go by without any problems, and then the problem appears again.
Any advice or suggestions? They would be much appreciated.
Mine was doing the same thing all day today. All I know is when it was cool I lifted up a bit on the lower burner an inch or so, and set it down. Next thing ya know, you guessed, it, it's working again...Not sure what's doing it, will keep checking for a solution.
Posted on Jun 14, 2008
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Mar 05, 2011 | GE JTP15 Electric Single Oven
JTP15 Oven - Shuts down after preheating
It sounds like the module is momentarily losing power when the bake relay clicks off. Does it do the same thing when you use broil?
Post back with the complete model number and I will try to find the wiring diagram for it and we will walk through checking it.
Nov 03, 2007 | GE JTP15 Electric Single Oven
Oven shuts down
i was on one once and the blower in the back has a screen behind it and it was clogged i cleaned it and it fixed it dont know if this will help
May 27, 2010 | GE JTP15 Electric Single Oven
As the oven heats up toward the set temperature,
Usually this is a problem with the temperature sensor or it's wiring. Sometimes this is caused by a failure in the control board. If you eliminate the temperature sensor as being the cause (either by measuring its resistance or by replacing it) and it seems to be the control board, then we can help you with that. We fix control boards at
Sep 23, 2009 | GE JTP15 Electric Single Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
373 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
