Question about Fisher Paykel EcoSmart GWL15
Pride 5.5 (mw059au)
Stop start problem
Is it the Main computer bpoard or the lid switch
Thanx
    Genius:
  • 1,224 Answers
It could be the lid switch but i need little more detail cause in between cycles its supposed to start and stop
to test washer completely empty run threw cycle write down on paper what the cycle does starts and stops
starting and stoping inbetween cycles has a 10 to 30 second delay to next section of cycle
post back comment i read my comments to improve myself better
Posted on Jun 10, 2008
My smartdrive pride lid came off and I fixed it but now the machine won't work, any suggestions please?
Possible that the lid switch alignment is not proper and so does not activate when the lid is closed. Please reset this lid once again and check the switch continuity with a meter when the lid is shut
Jan 14, 2013 | Washing Machines
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
When you push the start button it beeps but nothing happens. F&P pride is model
HI Richard sounds like your LID SWITCH is faulty.Turn the machine off at the wall and remove the 2 screws at the back of the top panel.Now gently lift the panel and rest it on the lid.It still has the display module wires attached.Now look to the right hand side of the computer and you will see a blue and black pair of wires leading under the hob and connected with another pair of wires that go under the computer.The blue and black wires are your lid switch wires.When the lid is closed they should have conductivity between them.Have you got or can borrow a multimeter to test the reed switch?If you have conductivity between the 2 wires then the machine will work when you push the start button but if the 2 wires do not have conductivity between them then the machine will only beep.Does the machine do nothing even on the spin cycle?Please reply on additional information and how you would like to proceed.Looking forward to your reply.
Oct 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Fisher and Paykel Pride 5.5kg washer will not start it's cycle? All the lights come on but it will not start? No beeping? Can anybody help me?
it could be a reed switch (lid sensor) located under right hand side of hob under lid ...this may solve your problem
Feb 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
The door on my washing machine got stuck,now ive opened it,it will not work as it blows the fuse in the plug and main box,its an old washer,is it worth having it repaired thanx
i am suspecting its the little safety switch which is activated by the lid, when opened it shuts off the machine, during spin and some models anytime. look for this switch, i think it is damaged and shorting out. look for it where lid makes contact with washer. it is an inexpensive part.
Aug 26, 2009 | Washing Machines
Need to reset lamp counters on a sharp XG-V10WU
1 turn projector switch off
2 remove lid and remove lamps
3 replace lid with out lamps
4 turn main switch to the on position
5 press the on switch on top
6 press enter
7 flip main switch to the off positon
8 replace lamps and lid
your done!!!!
Aug 03, 2009 | Sharp Projector Lamp for XGV10WU
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Does not drain all of water out unless you raise the lid during spin cycle
This is sometimes the coupler, sometimes timer has shorted out.
Sep 22, 2008 | Kenmore 23822 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
229 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
levittg
Level 1 Expert
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
