Question about Whirlpool Electronic Window Air Conditioner ACQ158XR
WHIRLPOOL ACQ088MRO When turned on it makes a low buzz kind of noise but the fan does not come on.I went through all the settings without any positive results! Is it the fan or the motor?What can I do? Help!!
  • Anonymous Jul 14, 2008
    It seem the fan or motor is trying to go on but there seems to be not enough power to get it going
  • 61 Answers
Take what covers off you can to see if you can look at the fan wheel. With the power disconnected, make sure that the wheel spins freely. Sometimes stuff gets in there and blocks the wheel. Hope that helps. From there it goes to checking controls and other functions of the unit that may require Whirlpool service.
Posted on Jun 10, 2008
  • 63 Answers
I would have to say it might have a bad fan but you could try oil on the fan motor bearings it may free it up
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Laptop make buzzing noise low to high it goes. click on speaker icon it stops for a min but come back again and keep buzzing left side bottom corner .
Hi There and Welcome to Fixya.
This on and off buzzing noise in the system indicates that the fan is not operating as designed and needs to be replaced as soon as possible. You may refer to Lenovo's consumer support site for replacement/repair options:
Lenovo Consumer Support
Please understand that this kind of work requires a certified Lenovo technician in order for it to be completed.
Thanks for using Fixya.
Feb 19, 2011 | Lenovo 3000 Y410 Laptop
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
GE AGL05 Air Conditioner Problem
Try the fan only setting. If it still buzzes, that would mean a fan issue. An object obstructing the fan, or a bad fan motor. If it runs on fan only, but buzzes on a cooling setting, that would indicate a compressor issue.
Aug 12, 2009 | GE AGL05 Air Conditioner
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Fan or capacitor?
I would say the motor is bad but to be sure test the voltage to the motor with a multimeter, you can also phisically spin the motor and if that makes it work a little not as fast and blow enough air then you know its the motor this works if you dont have a multimeter.
Dec 09, 2007 | Whirlpool Electronic Window Air...
WHEN EQUALIZER IS ON LOW GRADE BUZZING/HISSING HEARD.
Have you isolated the problem to the equalizer only? By that, I mean remove it from the signal chain and bypass it completely. That's the first thing.Does the system make noise without it in? If dead quiet when removed then you go to step two.
If the noise returns when the EQ is reconnected, you should eliminate crappy or broken cables, connectors etc. Replace with a known good working set. Still there? Buzzing infers either a ground issue or some kind of power supply problem, only if the previous stuff is eliminated. Do this first, then ask again.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
Whirlpool Electronic Window Air Conditioner ACQ158XR Logo
613 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
