Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool Thin Twin Washer
The spinning mechanism within the washer that usually spins and pulls down the clothes continually throughout the wash is spinning uncontrollably throughout the wash, without actually "catching" and washing any of the clothes. It's still somewhat functional, but the load size is cut in half. Any suggestions?
Whirlpool twin stack washer , its working properly but all towels and wool cloth ruined , all the other clothes r full with towel flur
Posted on Jul 25, 2011
  • 63 Answers
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Posted on Jun 10, 2008
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
Whirlpool AWN 321 washer continues to drain water out of drum throughout the whole wash and rinse cycles. The consequence of this is the machine continually draws in hot and cold water to achieve the...
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Jun 30, 2008 | Whirlpool Washing Machines
Whirlpool Thin Twin clothes still wet after spin
Possible your outlet filter is clogged, check this out. If this is not the problem check out your outlet pump. Ofcouse after you have the wall plug off.
May 24, 2007 | Whirlpool LTG6234D Front Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
174 people viewed this question
Dan Webster
Dan Webster
Sal De
