Question about HP DesignJet 500ps (42 in.) InkJet Printer
MY HP DESIGNJET 500 DOESNT WORK
Hi, let me tell you what it does.. Sometimes when we are printing it pops out in the screen a message of an error and ask to reset the printer, so when you try to turn it off it doesnt work, we cant turn it off, so we diconnect it from the energy for a minute and try to turn it on again, the green botton of the power turns on but not the screen.. so we disconnect it for weeks and it turns back to normal.. this event have happened before.
Right now happened again.
  • cuzca Jun 10, 2008
    Right now the screen says system error 86:01but it doesnt turn off
  • wayne churchill May 11, 2010
    What is the error code???
  • 300 Answers
System Error: 86:01
Problem
Description:
Carriage-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then
try the following:
 Too much friction in the Slider Rod. Enter the Printer Information
utility and check the Scan-Axis usage. If the
percentage is close to 100%, then lubricate the Slider Rod.
 The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
 Perform the Carriage Movement test
Posted on Jun 10, 2008
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
FITTED NEW ENCODER SENSOR TO DESIGNJET 500 STILL GETTING 81/01
Download the service manual here:
http://h30499.www3.hp.com/t5/Printers-Designjet/HP-DesignJet-500-24-Error-Message-81-01/td-p/1160495
Refer to page 1-4 for more troubleshooting ideas...it is most likely the paper axis motor or the transmission gears...or you didn't fully seat the connector to the new encoder board..
Sep 23, 2011 | Office Equipment & Supplies
Hp designjet 500 is saying ink cardridges are empty but thay are new
Here is a link where you can download a copy of the owner's manual for your printer:
http://h10032.www1.hp.com/ctg/Manual/c00748239.pdf
In the manual are detailed explanations of error messages, what to do if it won't print, how to clean the print heads, how to align the print heads, and so much more. Shown here is a page from your the manual regarding ink supply issues. (Zoom in to make print bigger)astucia01.jpg
Apr 18, 2011 | HP DesignJet 500 InkJet Printer
Double printing sometimes-HP DesignJet 500-800 series
When was the last time the heads were aligned? If that's not it, it's the belt.
Dec 17, 2009 | HP Office Equipment & Supplies
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
try processing the file in the PC instead
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
THE SCREEN OF MY HP DESIGNJET 500 DOESNT WORK
I would suggest taking out all the consumables. Printheads, media and cartridges. Unplug for upwards of 20 seconds before plugging it back in but leaving the consumables out.
Try turning on the plotter. If it appears working properly, load all consumables one by one, cartridges first, then printheads, then media. Attempt to print a test page if it works.
Or try a different outlet. Maybe the one your using has a problem and doesnt produce enough electricity.
Nov 26, 2008 | HP DesignJet 500ps InkJet Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
1,120 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
