Question about Volfenhag ZX-8300 Car Audio Amplifier
Protection light When I installed my Volfenhag zx8300 for the first time it worked great. The next day I tried to use and the protection light came on. So I unhooked it and did'nt reinstall it for a month. After reinstalling it the protection light came on again once I turned it back on. Could you please give some reasons why this is happening, and what I can do to fix this problem? Thank you very much for your help in this matter.
  • 3 more comments
  • dtang Jun 10, 2008
    How do I check the transistor? And thank you for your help.
  • dtang Jun 11, 2008
    thanks, but i cant find the link showing how to check the resistors for the for channel zx 8300.
  • dtang Jun 12, 2008
    you are being very helpful. but now i need to know once i removed the back of the zx8300 an after removing the screws on the board. what do i need to do to get the board out? it has eleven grey brackets holding the board down. thank you in advance for your help again.
    did you recieve the pictures i sent?
  • sperrault123 Feb 19, 2009
    i have a volfenhag zx8300. i installed it and it worked overnight, the next day i turned on my truck and the protection light was on. it hasn't worked since
  • 631 Answers
It's likely that there are shorted output transistors in at least one channel. If you want to repair it yourself, you'd have to determine which transistors are defective and replace them. The following page will help guide you through the basic troubleshooting.
Basic Amplifier Repair Primer
Posted on Jun 10, 2008
  • 2 more comments
  • Perry Babin Jun 11, 2008
    On the page (link) provided, read the section labeled:
    Transistor Failure/Checking Transistors
    There's a link to a page that shows you how to check the transistors. Let me know if you need more help.
    You need to check the transistors. Pull the clamps off of the transistors (after disconnecting the amp from the power source) and give me the numbers on the transistors. There will be multiple transistors with the same number. Give me the 5 or 6 numbers common to the groups of transistors. For example, you will likely have several with the number Z44. Others will likely begin with an A or a C.
  • Perry Babin Jun 12, 2008
    Can you send me a photo of the inside of the amp?
    babin_perry@yahoo.com
    I didn't receive them. If they were larger than 10 megs, they probably won't make it through.
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
The red protect light comes on, i dont know how to make it go green so it will work. please help!!
Devices with several light emitting indicators would each display as observation of manufacturers installed features. Red indication is power cciuit indication, yelow as alternate warning where green is indication of regular fucntionality. Once the device is least malfunct, every light is an equal expectation. Usually with amplifeiers, the red light has to be on throughout until stereo became powered on to porduce green light effects as radio expectations.
Feb 14, 2011 | Volfenhag ZX-8200 Car Audio Amplifier
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
May 21, 2010 | 1997 Volkswagen Jetta
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Protect light
check speaker wire is not grounded and/or the proper impedence is followed. Those amplifiers are 2 ohm stereo stable. Know the difference.
Remove speaker wires and try amplifier.
Add 1 speaker at a time until the problem recreates itself, or test them with an ohm meter.
Dec 20, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Protection light
If the amp goes into protection with no speakers wires connected to the amp and no signal cables connected to the amp, the amp probably has shorted output transistors.
If that's the case, they would have to be replaced. Most people simply have the amp repaired by a qualified tech. If you want to try to repair it yourself, read the following page:
If the amp failed after only a short time, the speaker ohm load may have been too low. If it wasn't lower than the amp is designed to run, the amp may not be suitable for your needs.
May 06, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Subs stopped working & protect light on the amp is red...
well at this point i would say it is both,, the subs fried because your amplifier passed dc [direct current] and fried the voice coils on your subs....return them if they are under warranty,, the amplifier sound like you either operated it beyound its specifications or it has a defective output stage allowing it to pass or leak dc....it turned the voice coils into the equivelent of the runners in a toaster oven....when an amp passes dc it is going to do so to whatever speakers you hook to it....so either bring it to a shop to be fixed/ return it to place purchase for exchange or throw it away.....or you will continue to experience the same problems....I am sorry..ps the amp goes into protection when it detects a short...[ the short is produced by the amp and it is detecting its own fault and putting it in to protection after it BURNS up your drivers....
May 16, 2007 | Volfenhag ZX-4712 Car Subwoofer
Volfenhag ZX-8300 Car Audio Amplifier Logo
197 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
