Question about Dell Latitude C400 Notebook
After repair, C400 won't power up.
I recently opened the cabinet to replace a sound card, and to investigate why my the pc would not charge a good working battery.
Once I reclosed the cabinet, the green power light comes on but the PC will not power up.
To compare to make sure I didn't put it back together incorrectly, I opened another working C400 and closed it up again and now it is getting the same problem.
Is it possible that the unit has a required specific power on sequence once it has been opened?
  • hindsite2020 Jun 10, 2008
    Should also note that other than the noted sound card and charging issue, the unit being repaired was working fine otherwise.
  • 54 Answers
It have some hardware problem take it to service centre as soon as possible
Posted on Jun 10, 2008
SOUND CARD REPLACMENT
On a desktop it's easy to replace the sound card. Remove the power cord, open the case then purchase a PCI Sound card that will fit into one of the PCI Slots. You present sound card might be what is called an on board sound card (which is built into the motherboard). You won't touch the onboard sound card, you will simply add a pci sound card.
May 12, 2012 | Dell Dimension 4100 (-JM0TB01) PC Desktop
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
I am having the computer with Intel 845GVSR motherboard,P4 Processor,1 gb RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working...
For that first open cpu cabinet then refix RAM memory try it in defferent slot on motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings goes to defaults.
Then open processor fan and processor then refix both.
Clean dust from all parts.
Reconnect ATX power connector to motherbord.
Reconnect power cable and sata or ide cable to harddisk.
If any PCI cards are installed then remove it from pci clot then check.
Make sure your motherbord is not ground with cabinet check in outside of cabinet .
Let me know if you need further assistance.
Nov 10, 2009 | Intel D845GVSR Motherboard
The usb of my dell latitude c400 notebook is malfunctioning
Unfortunately, I have seen this many times. One of the major problems with the C400 model was the USB port failing. I have had many of them replaced under warranty, and I have repaired some. The USB port breaks loose from the mother board and stops working. It is possible to SOMETIMES disassemble the laptop enough to get to the port and re-solder the USB port connections. But is is a slow process for experienced people. And it does not work all of the time. i know that this is not the answer that you wanted.
Good luck with it.
~ Spoem
Mar 18, 2009 | Dell Latitude C400 Notebook
Latitude c400 no longer detects internal wireless card
device driver's are different from one operation system to another...you need to find the driver for the current operating system...
Sep 06, 2008 | Dell Latitude C400 Notebook
Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
Aug 12, 2008 | Dell Latitude C400 Notebook
My Dell Latitude C400 does not power on. I bought a new power cord and battery and it still does not power on. Is it unsalvageable?
Do you see a green charging light when you plug it in?
If not, i would reccmond scraping it for parts and sell it on ebay, craigslist or somewhere else.
Jun 01, 2008 | Dell Latitude C400 Notebook
Dell Latitude C400 PC Notebook
yes the power jack need to be replaced or your power adpoter maby no good any more more likley teh power jack all dells have these heat isses
Jan 23, 2008 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
82 people viewed this question
Alun Cox
