Question about EuroTech EWF172 Front Load Washer
Drum won't turn
Washer will fill and drain but won't turn. HELP!
  • Episteme Aug 17, 2008
    Washer drains but drum will not rotated during spin cycles. Drum can be rotated manually with door open. "Pin trap" clean. Belt intact, tight and turns drum when moved manually.  Control indicator moves as cycles proceed. Motor shaft does not rotate.
    Sergeant:
  • 225 Answers
If it will turn freely by hand when the door is open, it could be that the motor brushes have worn out. Are there any blue lights flashing inside or underneath the machine when it turns or tries to turn, or is there a lot of black powder on the floor under the motor?
Those are signs of the brushes wearing out. They usually cost £5 to £15 depending on manufacturer and a "handyperson" can usually fit them without difficulty.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
D
Posted on Jul 13, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Hotpoint Washer/drier problem
just wondering if the brushes are worn out on the main motor if the drum wont turn can you open the door and turn the drum by hand should turn,may even be the belt has snapped or gone slack,roy
Mar 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Washer fills but won't agitate or spin
Try making sure the belts are actually on the drum, probably have to turn upside down. Sounds silly but a lot of simple things are missed.
Apr 02, 2012 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Ge whdvh626 washer fills and drains. drun does not
I took off back plate and noticed belt was off. I also noticed that pulley was very loose. I ordered new pulley and belt and replaced myself. Thanks.
Dec 16, 2009 | GE WSXH208A Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
EuroTech EWF172 Front Load Washer Logo
148 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
