Question about Gateway FPD2275W LCD Monitor
Benq FP937s Monitor - no display
When booting up the PC, the monitor (having been on standby mode)LED changes from yellow to green, the monitor flashes the boot screen for less than a second then goes blank, but LED stays green. I have tried with both DVI-D and D-sub connectors with same result. I have tried booting with another monitor and all goes well.
So problem is in monitor.
With no comms cable connected I turn monitor on (from off not standby), LED goes straight to green and monitor shows the purple screen with BENQ logo, then shows a message there is no signal, and then goes blank with LED going back to yellow.
I have read with interest that other people have similar symptoms on other versions of this moniotr with suggestions that the backlighting is at fault. However as there are 4 backlights and 4 circuits feeding them I cannot see that all 4 can go at once unless there is a common element. What is the common element that appears to overload and then cut out because clearly the monitor does light the screen for a short period then switch itself off?
  • basgast Oct 13, 2008
    When I turn on my BENQ FP937S monitor it show a faint image of the Benq logo (can only be seen in the right angle/light). So it seems to me the screen still works but their is something wrong with the light in it (I'm not technical at all!). Can someone maybe help me?
    Scholar:
  • 47 Answers
Usually this type of problem is due to a faulty electrolytic capacitor on the monitor's power supply board or the inverter board that powers the backlight lamps. If you have a soldering iron and some technical skill it's possible to repair this yourself, if you can determine the bad component. Look for a capacitor with a domed top, or what looks like corrosion or leaked fluid on the top. If you replace the capacitor with one of the same rating and type (in volts and microfarads (uf)) it may fix the problem.
The backlights are usually not the problem in this case, I've fixed dozens of monitors and it has always been a faulty capacitor.
If you are willing to try this, there are lots of resources on the internet that will provide instructions for how to do this. Replacment capacitors can be purchased (usually $0.50 or $1 each) from many electronics suppliers and on eBay.
Good luck, happy repairing!
Posted on Jun 10, 2008
Hello!
Don't know if you still have the monitor, but maybe this helps someone:
I had exactly the same symptoms.
In my case, the solder points at the power connector were broken. The connector is not tightly fixed and can move a bit. This causes the solder points to break when plugging and unplugging the power cord for a number of times. I unsoldered it, glued the connector to the PCB and resoldered the pins.
The only problem is to get to the PCB, as the two PCBs are mounted in the metal enclosure and the display cable can't easily be unplugged from the PCB. I lifted the metal housing just enough so i could unscrew the PCB with the display cable and unplugged the connector to the power supply board, which is easy to unplug.
Posted on Feb 05, 2011
My benq 15 inch crt monitor does not going to standby mode with no display and noisy power supply
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
Jan 10, 2014 | BenQ V551 (White) 15 in.CRT Conventional...
When starting the computer the screen stays black. Only the green light is on. It gives short the bios start up screen, after that it's only blach.
windows cant start up ...try to press F8 kay before startup to open in safe mode and if that cant be you will need to reinstall or repair your windows.
let me know more about
techbelkin
Jan 08, 2011 | BenQ FP937S 19" LCD Monitor
The green light comes on then it turns yellow the screen does not light up
There could be some issue in PC as well as in the Monitor also, to check Monitor, please follow the below steps-
1. Disconnect the VGA cable from the computer.
2. Please check if there is any kind of display on monitor.
3. Please check what is the color of Montior LED, if it is still yellow and if there is no message on Monitor then there could be some issue in the monitor. For this, you need to get in touch with the Monitor manufacturer and get it repaired otherwise please get in touch with the computer manufacturer to get computer fixed.
Mar 30, 2010 | BenQ FP731 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
What is the triggering signal to power on the monitor?
Most modern monitors use the Horizontal sync line to determine when to go to standby.
Aug 18, 2006 | BenQ V773 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
1,604 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
