Question about Kenmore Dryers
Kenmore electric dryer
Cheked breaker and outlet... dryer is gtting power but does nothing at all. Was working fine 2 days ago.
    Genius:
  • 1,028 Answers
Ck door switch also ck connection of power cord could be burnt remove back (if top mount filter lower panel if door mount)look for white thermal fuse ck for closed circuit through fuse fuse is in motor circuit and has been known to blow for pluged or restricted vent system
Posted on Jun 10, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore Elite dryer it was working fine than blew the circuit breaker, I unpluged it reset the breaker pluged it back it and it sparked and blew the breaker again. I disconnect the motor in the...
If the dryer is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. or a wire is loose to breaker.
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the dryer is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. check outlet to find out !
Mar 29, 2012 | Dryers
Dryer was working fine until I turned off the breaker to work on an electrical outlet on the same circuit. When I was done I turned on the breaker all other outlets worked, I went to use the dryer and...
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
Jul 29, 2011 | Estate TEDS840JQ Electric Dryer
I have have an older kenmore electric dryer that won't start. Let me give you some detailed information about the events that happened prior to the discovered failure. -This dryer hasn't been used for a...
The heat is not a factor.Make sure you do not have a tripped breaker. Otherwis if you had a power surge to the dryer, ther could be electrical damage.
Aug 11, 2010 | Kenmore Dryers
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
Kenmore catalyst electric dryer. about 3 yrs old.
You may only be receiving 110 volts, instead of the 240 volts needed to operate. (Thus, only the light coming on)
Did you reset the dryer circuit breakers?
Are you receiving 240v to the plug?
-Chad
Jan 21, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
