Question about Dell Inspiron 6000 Notebook
Powers on then off
When I turn on my LapTop it sees to try to start up but then stops. I also noticed that when is pluged into the wall it doesn't show that its charging up.
  • 54 Answers
Check it your battery may be it is not properly installed
Posted on Jun 10, 2008
Laptop pluged in but wont charge
your battery is dead, try and replace it with another one and see if it charge.
Apr 11, 2013 | Dell Inspiron M5030 Laptop
So I bought a HP Pavilion tx2510us about 5 years ago and it served me well for the time being, but about a month ago I was using my laptop and I noticed that the battery icon showed it wasn't being...
You might check your device manager to see if there are any clues there before trying a new battery. Also, check your Power Options settings and see if there is a conflict.
Mar 18, 2013 | Computers & Internet
My Sony ereader touch isn't charging. Pluging it in to either the computer or the wall charger, and the light doesn't go on. The screen is frozen on the last page it turned to.
Hi suebagnall,
If the redlight does not come on, try the following:
1. Connect the reader to the wall charger (make sure you use the Sony Charger ACS5220)
2. Hit the Reset button at the bottom of the reader
3. Check if the redlight comes on
4. If so, leave the reader charging for 15 minutes to see if it takes the charge
5. If this does not resolve the problem, probably you will need to contact Sony to get it repaired
eBookBoy
www.digitalreader.freeforums.org
Jun 27, 2011 | Sony Reader Touch PRS-600
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My laptop wont charge
Sounds like to me you may have a bad battery. I would do a search for your model number for a battery. It is showing being plug in that means your charger is working, but your battery not taking no charge.
Aug 09, 2009 | Dell Inspiron 1525 Notebook
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Dell Inspiron 6000 Notebook Logo
Alun Cox
